TheGoat Posted May 9, 2011 Report Share Posted May 9, 2011 Anyone know what the best way to remove wheel weights is whilst avoiding damage to the paint underneath, on the wheel? i don't just want to go straight in with a screwdriver and lever the fuckers off. Link to comment Share on other sites More sharing options...
TheGoat Posted May 9, 2011 Author Report Share Posted May 9, 2011 ...i was thinking maybe heating them first. With a hairdryer or summit. Link to comment Share on other sites More sharing options...
VanWinkle Posted May 9, 2011 Report Share Posted May 9, 2011 Its only adhesive their held on with, Petrol on a rag placed over the weights for 5 mins or so should loosen that off enough to pry the weights off..rub off excess adhesive with petrol on a rag. Link to comment Share on other sites More sharing options...
BudgetBoy Posted May 9, 2011 Report Share Posted May 9, 2011 ...i was thinking maybe heating them first. With a hairdryer or summit. yep you could do that..the glue should soften for you to get your finger nail under it to lift it up. I myself would use a stanley blade and carefully prize a corner up,gently working it underneath,then as chill says bit of petrol on the rag to clean excess glue up. Link to comment Share on other sites More sharing options...
VeeTeeArr Posted May 9, 2011 Report Share Posted May 9, 2011 Use a plastic bladed spattula form the kitchen draw, no one will know Link to comment Share on other sites More sharing options...
zx6rrob Posted May 9, 2011 Report Share Posted May 9, 2011 Use a plastic bladed spattula form the kitchen draw, no one will know Good advice, we use what looks like a white plastic chisel at work. Link to comment Share on other sites More sharing options...
Sideshow Pob Posted May 13, 2011 Report Share Posted May 13, 2011 I tried a heat gun the other day and it worked a treat. You need to remove the weight first (carefully with a plastic spatula) leaving all that thick adhesive stuff behind. In the past I've used petrol, white spirit, brake cleaner, Mr Sheen and a lot of rubbing to then get this residue off but then I tried the heat gun method and it was sooooo much easier. Link to comment Share on other sites More sharing options...
