riversbikes Posted May 5, 2011 Report Share Posted May 5, 2011 Could someone give me the length of a stock mito shock, eyelet to eyelet? Thanks. Link to comment Share on other sites More sharing options...
cagimaha Posted May 5, 2011 Report Share Posted May 5, 2011 I'm afraid I don't have a standard mito shock to measure anymore but I would advise against using one! Even in the standard 125 they're not up to the job really. If you're looking for an alternative shock to go in a mito chassis then I can recommend an RGV250 unit. Dimensionally all RGV shocks are identical with slight differences in spring rate, damping and adjustability. Fitment requires the top shock eye narrowing slightly (easily done with a file) and a couple of washers on the bottom mount. Also the shock linkage needs to be reversed. Hope this helps, Ben. Link to comment Share on other sites More sharing options...
