Annaz Posted April 6, 2011 Report Share Posted April 6, 2011 I've developed a rattle coming from the front pads on my bike. It's an R1 4xv front end. One of the discs is very slightly warped but not enough to notice while braking. The holes where the pad pins go through are slightly oval so there's some slack there. The noise is definately coming from the pads and I'm concerned that this will only get worse. I'm thinking that sooner or later I'll need new callipers but I'm concerned in the short term whether it's dangerous to ride. The chattering is only very slight and stops as soon as the brakes are applied. Any wisdom greatly appreciated, especially as warm dry weather is on the cards Cheers mick Link to comment Share on other sites More sharing options...
Gregorious77 Posted April 7, 2011 Report Share Posted April 7, 2011 mine rattle over bumps. pretty standard problem on a lot of bikes I think. Link to comment Share on other sites More sharing options...
lorenzo Posted April 7, 2011 Report Share Posted April 7, 2011 Springy plates on the back lost their springiness? Either you won't die. Well you might, but it won't be your brakes fault. Link to comment Share on other sites More sharing options...
MonkeyJim Posted April 7, 2011 Report Share Posted April 7, 2011 check the anti-rattle shims that fit on the rear of the calipers, under the pad pins. There's a [very faint, easy to miss] arrow on them, which should be pointing 'up'. if they're not fitted properly, they can cause the pads to rattle. 'Cos they is the anti-rattle shims, innit? an' ting Link to comment Share on other sites More sharing options...
Phil Norton Posted April 7, 2011 Report Share Posted April 7, 2011 I've just had to replace the calipers on my R1 for exactly the same problem. The calipers had done over 50K miles and the slot that the pads fit into had 'opened up' and there were grooves at each end, this was allowing too much pad movement. Link to comment Share on other sites More sharing options...
Annaz Posted April 7, 2011 Author Report Share Posted April 7, 2011 I've just had to replace the calipers on my R1 for exactly the same problem. The calipers had done over 50K miles and the slot that the pads fit into had 'opened up' and there were grooves at each end, this was allowing too much pad movement. I think I'm heading in the same direction Monkey! I spotted that in the old haynes manual. You're right it is faint, I missed it first time round! Link to comment Share on other sites More sharing options...
Annaz Posted April 8, 2011 Author Report Share Posted April 8, 2011 The Rasta keybord is canny good like, an me geordie keybord is geet good 'n'arl but a divvunaar which 'n is best like yernaar? Link to comment Share on other sites More sharing options...
Annaz Posted April 11, 2011 Author Report Share Posted April 11, 2011 Springy plates on the back lost their springiness? Either you won't die. Well you might, but it won't be your brakes fault. Tried this at the weekend, bending the springy things to allow more springyness, and by jingo it's worked . Adjusted the head bearings for the second time too, hopefully that'll be it for a while Link to comment Share on other sites More sharing options...
lorenzo Posted April 11, 2011 Report Share Posted April 11, 2011 Tried this at the weekend, bending the springy things to allow more springyness, and by jingo it's worked . Adjusted the head bearings for the second time too, hopefully that'll be it for a while This has proven it once and for all: I am amazing. Thankyou. Link to comment Share on other sites More sharing options...
Annaz Posted April 12, 2011 Author Report Share Posted April 12, 2011 This has proven it once and for all: I am amazing. Thankyou. Put some mair butta on ya tatties Link to comment Share on other sites More sharing options...
