Bernster Posted April 4, 2011 Report Share Posted April 4, 2011 Some going cheap, just wondered if the mounts will lune up. Link to comment Share on other sites More sharing options...
kaighn80 Posted April 4, 2011 Report Share Posted April 4, 2011 if its glass bodywork and not original plastic i doubt it would even line up on the right bike, worst case you have to make some mounts, if it helps i managed to get 03-05 r6 bodywork to fit an fzr400 and look good enough to turn heads and i'm currently fitting 05 fireblade stuff to a 1986 vfr750, anything is possible with a big enough hammer and some duct tape. Link to comment Share on other sites More sharing options...
Bernster Posted April 4, 2011 Author Report Share Posted April 4, 2011 if its glass bodywork and not original plastic i doubt it would even line up on the right bike, worst case you have to make some mounts, if it helps i managed to get 03-05 r6 bodywork to fit an fzr400 and look good enough to turn heads and i'm currently fitting 05 fireblade stuff to a 1986 vfr750, anything is possible with a big enough hammer and some duct tape. Cheers, as it's 2nd hand it's already been pre-drilled so I'd have to modify the mounts to get it to fit. I'll sit it out and see if some 04/06 stuff turns up. Link to comment Share on other sites More sharing options...
Mark/Foggy Posted April 4, 2011 Report Share Posted April 4, 2011 Haven't tried it to be honest, but should fly on, the chassis were really similar and the headlamp bracket not far off. My guess would be that the Ram Air tubes could be a bit of a wrestle, but there's enough room to trim back the inner fairing sides to meet up with the Rad. I'm sure that I sold some-one on here some body work to do just this, can't remember who now though. Link to comment Share on other sites More sharing options...
Bernster Posted April 4, 2011 Author Report Share Posted April 4, 2011 Haven't tried it to be honest, but should fly on, the chassis were really similar and the headlamp bracket not far off. My guess would be that the Ram Air tubes could be a bit of a wrestle, but there's enough room to trim back the inner fairing sides to meet up with the Rad. I'm sure that I sold some-one on here some body work to do just this, can't remember who now though. Nice one might worth the pennies then. Cheers. Link to comment Share on other sites More sharing options...
Mark/Foggy Posted April 7, 2011 Report Share Posted April 7, 2011 Foo? Course, Calling Foo, Foo to the R1 Shaped Phone Pls........ Link to comment Share on other sites More sharing options...
Romski Posted April 14, 2011 Report Share Posted April 14, 2011 is not that martini r1 a 06 with 07 bodywork?? Link to comment Share on other sites More sharing options...
