ferg Posted March 28, 2011 Report Share Posted March 28, 2011 Just to check I'm thinking things through correctly I have a CG 125 which isn't starting. My brother rode abused it for a year or so and now I've got it back to sell it, not that it ever left the family garage.... Anyway, it's a kick only model and the battery is flat. Can anyone confirm that it doesn't have to be charged for the beastie to start? In my head there's no reason for it not to but... I've put fresh fuel in and drained the older stuff and carb out. There's also a fresh plug in as well but I've older plugs that do work to switch around too. So it did run a bit a few months back but only on the choke. Now it wont catch at all. Through as much kicking or bump starting as you want. There is a lovely bright consistent spark when you check the plug. I've tried Bannoffe's heating up the plug idea and it did come closer to 'almost catching' but it still didn't. So air and fuel being the two normal avenues of detection... can some one guide me a bit better before I rip the carb off for a look? The plug doesn't look that wet so would I be right in thinking that fuel may not actually be getting in to the combustion cycle? (My thought process being that it's not being burnt so why else would the plug be dry?) Hence my gie for whipping the carb off! Link to comment Share on other sites More sharing options...
deviant Posted March 28, 2011 Report Share Posted March 28, 2011 It should fire up fine without a battery in. I'd say fuel is your problem. Link to comment Share on other sites More sharing options...
ferg Posted March 28, 2011 Author Report Share Posted March 28, 2011 So carb off is the right way to go? Link to comment Share on other sites More sharing options...
bezzer Posted March 28, 2011 Report Share Posted March 28, 2011 So carb off is the right way to go? Yep, pound to a pinch it's all gummed up, strip it down and use carb cleaner too clean it out and soak/blow the jets clean Link to comment Share on other sites More sharing options...
Kayla Posted March 28, 2011 Report Share Posted March 28, 2011 You could try dropping a little fuel or acetone down the spark plug hole and encouraging it that way. Link to comment Share on other sites More sharing options...
lorenzo Posted March 28, 2011 Report Share Posted March 28, 2011 Can of easy start will tell you where your problem is, if not fix it. Give it a good dose, if it runs for 30 secs then dies then you've got no fuel going in, something in the carb, prob jets but could be all sorts. If it runs indefinately so long as you're revving it up a fair bit, but dies when you let it settle then your pilot jets blocked (90% certain it'll be this, they're tiny and easy to block). If it doesn't run at all then it's something else (no shit). Link to comment Share on other sites More sharing options...
Evilchicken0 Posted March 29, 2011 Report Share Posted March 29, 2011 I'd say the running jets blocked - clean the carb. You need the battery in though to complete the circuit ... get some motorcycle jump leads from Halfords (they're about £5) and connect it to another 12v battery (as long as the bike has a 12v system). Although it should run with a flat battery it helps to have power already there so the plug sparks a bit better Link to comment Share on other sites More sharing options...
