monkeyfumi Posted December 12, 2008 Report Share Posted December 12, 2008 Would post 2006 R6 Fork legs fit 98+ (showa) Aprilia RS250 forks? I realise that there would be changes to springs etc, and wheel offset adjustments. They are both 41mm, and it seems a simpler way of upgrading to radial caliper mounts, without swapping the whole fork (potentially needing new yokes etc) and no-one makes radial fork bottoms to suit the RS forks. Would the damping adjustment be an issue? Any thoughts / advice? Link to comment Share on other sites More sharing options...
Gobert23 Posted December 12, 2008 Report Share Posted December 12, 2008 You've got more than just the fork to measure... You need to measure the stem and the yokes (I would doubt that they'll marry up, without modification). Have you considered late ZX-6R (636? B-model?) forks? As that's been done before... Link to comment Share on other sites More sharing options...
roadracer Posted December 12, 2008 Report Share Posted December 12, 2008 You've got more than just the fork to measure... You need to measure the stem and the yokes (I would doubt that they'll marry up, without modification). Have you considered late ZX-6R (636? B-model?) forks? As that's been done before... I do believe the chap is asking if the stanchions of an 06 R6 will fit onto the Aprilias outer fork tubes. I'm not touching that with a ten foot pole but it could very well be an idea to fit the Kawasaki's forks(do they have DLC coating??) as it's a lot less mucking about Link to comment Share on other sites More sharing options...
monkeyfumi Posted December 13, 2008 Author Report Share Posted December 13, 2008 I do believe the chap is asking if the stanchions of an 06 R6 will fit onto the Aprilias outer fork tubes. I'm not touching that with a ten foot pole but it could very well be an idea to fit the Kawasaki's forks(do they have DLC coating??) as it's a lot less mucking about yes, i was refering to the stanchions only. It was a bit of a pie in the sky question at this stage, but it seems possible to my mind. If the stanchion dia. is the same as the yamaha, would the yamaha fork lower fit in the aprilia slider? Alternatively could just the radial bottom be pressed/threaded onto the aprilia stanchion? Link to comment Share on other sites More sharing options...
roadracer Posted December 13, 2008 Report Share Posted December 13, 2008 yes, i was refering to the stanchions only. It was a bit of a pie in the sky question at this stage, but it seems possible to my mind. If the stanchion dia. is the same as the yamaha, would the yamaha fork lower fit in the aprilia slider? Alternatively could just the radial bottom be pressed/threaded onto the aprilia stanchion? There is more than just the stanchion diameter involved. The stanchion would physically slide into the same size hole, yes, but you see, the cartridges in the Yamaha forks screw into the threaded bottom of the radial-mount section, whether the RS's internals could be made to mount in the same way I'm unsure. Don't know if the axle would fit either, once the radial mounts were in place. Then the RS's brake discs may not have the offset or diameter that the R6's radial brakes require, so the calipers would clash with the discs in their way. and you may need new spacers to hold the wheel centre if the radial mounts are thicker than the stock RS's fork bottoms. etc etc. I'm not saying yay or nay, it's beyond my scope, but just a few things to think about that may have been overlooked. Personally I'd say follow the ZXR forks route, we know it's been done and the DLC coatings are actually very good, at the very minimum. Link to comment Share on other sites More sharing options...
