YZ faybo Posted March 13, 2011 Report Share Posted March 13, 2011 Morning all Has any body have any experiance of removing the blk paint one often finds on stock rads. Was thinking of using nitromorse but wasnt sure if it would damage all the little fins. Any help/tips would be appriciated. Link to comment Share on other sites More sharing options...
johnnymack63 Posted March 13, 2011 Report Share Posted March 13, 2011 Morning all Has any body have any experiance of removing the blk paint one often finds on stock rads. Was thinking of using nitromorse but wasnt sure if it would damage all the little fins. Any help/tips would be appriciated. Yep, I did this to my ZXR rad when I was restoring it. It's had layers of gold then blue, then black then silver paint. I just used Homebase paintstripper, a small scraper and took lots and lots of time. Link to comment Share on other sites More sharing options...
YZ faybo Posted March 13, 2011 Author Report Share Posted March 13, 2011 Cool, were you able to get it out from the little fins or ends only? wasnt sure if I could get it out from the fins by hosing it off without bending them over. Yep, I did this to my ZXR rad when I was restoring it. It's had layers of gold then blue, then black then silver paint. I just used Homebase paintstripper, a small scraper and took lots and lots of time. Link to comment Share on other sites More sharing options...
kanerdog1x1 Posted March 13, 2011 Report Share Posted March 13, 2011 assuming the rad is in good nick then the fins will still be pretty strong. you can use a tooth brush and as long as to scrub along the 'grain' of the fins you should be ok. let the nitromors do all the work tho. i can see this taking ages.... if however the rad is in poor condition then the fins will just collapse as they could be rotten. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted March 17, 2011 Report Share Posted March 17, 2011 Tooth brush + Nitromors ??? won't the toothbrush melt. maybe a brass brush Link to comment Share on other sites More sharing options...
kanerdog1x1 Posted March 18, 2011 Report Share Posted March 18, 2011 nope, common as toothbrush. get down tescoland and buy the cheap 19p ones. stiff bristles. Link to comment Share on other sites More sharing options...
