MarkyRR Posted March 5, 2011 Report Share Posted March 5, 2011 I'm getting close to needing to replace the chain/sprockets on my B1 ZX9R, and have seen for the same price, there's either an X ring, or an O ring. Whats the difference/recommended?? The bike isn't used on the track, or for anything too fast, etc, just mainly for commuting duties. Does one give better lifespan, etc than the other? Whats the PB thoughts?? Link to comment Share on other sites More sharing options...
rossm Posted March 5, 2011 Report Share Posted March 5, 2011 X rings are meant to be better as they have two sealing points Link to comment Share on other sites More sharing options...
kwakbiker Posted March 5, 2011 Report Share Posted March 5, 2011 As Ross said, X as its meant to keep the grease in longer, whether in reality youll notice the difference is another story but for the same price.... Link to comment Share on other sites More sharing options...
MarkyRR Posted March 5, 2011 Author Report Share Posted March 5, 2011 Thanks chaps....I've read a bit more about it aswell now, and thats the only difference I can see aswell..... 'X' version it is then. Link to comment Share on other sites More sharing options...
lorenzo Posted March 5, 2011 Report Share Posted March 5, 2011 Do a search on here, a few people have had some issues with chains and there seems there was a trend towards one brand failing. I can't remember if it was afam or regina. I can remember that tsubaki have very few failures, worth the mone as a failed chain can cost a good bit to sort out the damage it causes. Link to comment Share on other sites More sharing options...
Dirtmonky Posted March 5, 2011 Report Share Posted March 5, 2011 In your position get an x ring. Regina is another brand name for Renthal chains I believe Link to comment Share on other sites More sharing options...
MarkyRR Posted March 6, 2011 Author Report Share Posted March 6, 2011 0.01bhp? This is the chain for me - the old girl needs all the help she can get! This is the one I was considering:DID Gold Chain/Sprockets Seems a decent enough price, doesn't it? Thought DID chains were s'posed to be OK too? Link to comment Share on other sites More sharing options...
BudgetBoy Posted March 8, 2011 Report Share Posted March 8, 2011 I guess its like anything mate.As long as you look after it im sure it will give you miles of trouble free motoring.Maintain the chain by cleaning & lube and im sure it will be fine. But if you cut an O-Ring, it has the cross section of an 'O', and if you cut an 'X' ring, it has the cross section of an 'X'. The thinking behind the 'X' ring is it provides two sealing surfaces to keep the lubricant in the rollers while the 'O' ring only has one sealing surface. The 'X' ring is also supposed to have somewhat less resistance as the chain goes around the sprockets.So if the X ring is the same price as the o ring then get the X ring one. Make your choice...... P.S I have heard the gold ones give you another 2bhp at the wheel.. Link to comment Share on other sites More sharing options...
