chirpy999 Posted February 27, 2011 Report Share Posted February 27, 2011 Hi, had a frame powder coated and a few of the threads have paint on them. How can these be cleaned up so I can frefit things like the fuse box holder???? Thanks Chirpy Link to comment Share on other sites More sharing options...
rossm Posted February 27, 2011 Report Share Posted February 27, 2011 Some of these should do the trick Link to comment Share on other sites More sharing options...
Mr.Pigdog Posted February 27, 2011 Report Share Posted February 27, 2011 Simple!buy a few metric taps(usually m6 x1,m8 x1.25),could also get dies to clean up any bolts as I'm assuming it's an old bike. Link to comment Share on other sites More sharing options...
chancho196 Posted February 27, 2011 Report Share Posted February 27, 2011 If on a budget, or unable to get to a shop, you can file slots into the end of a bolt (same thread) and this will clear the coating as you screw it in. Just put the bolt in a vice and file 2 or 3 slots, lengthways, into the end of the thread. A tap is still the best way though so be careful. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted February 28, 2011 Report Share Posted February 28, 2011 The best and easiest way is a tap and die set - they're not expensive and are useful for cleaning threads (like disc bolts and the wheels). get a set off the bay or a tool wesite and get them sent to you. Don't hurry this with dodgy tools. Link to comment Share on other sites More sharing options...
