zx6rrob Posted February 13, 2011 Report Share Posted February 13, 2011 Monkey! I`m looking at you. Or any other twonk thats done this before.... How much slack is needed in the cable? Any hints or tips? No worries about the cover bolts, had them out about 3 months ago and copperslipped them, unbeleiveably they all came out without a hitch!!! fuck knows..... I reckon its the valve cables that need adjusting, got a ticking noise coming from that area thats really fucking me off, reckon its the valve flapping about the place. Link to comment Share on other sites More sharing options...
lewis203 Posted February 13, 2011 Report Share Posted February 13, 2011 I had a funny ticking noise too and an EXUP cable adjustment sorted it. Needs to be 1.5mm at point A: Link to comment Share on other sites More sharing options...
ronenige Posted February 13, 2011 Report Share Posted February 13, 2011 Not got the manwell in front of me but the 5vy has a similar set up and all you have to do is get it less than 4mm if you move the cable , so long as there is a small amount of slack it'll be ok , pay attention to the nipples in the pulley wheel , if they do not move freely the cables will eventually start fraying , lubricate them with silicone grease as its the only stuff that stands the temperature , If you pull the exup valve out completely you will probably find there is a bit of play in the bush and thats probably where a lot of the noise comes from , pull the valve out of the casing and check the bushes etc , grease it all with silicone grease and bung it together , they all make a bit of noise and its a lot better than it seizing Link to comment Share on other sites More sharing options...
zx6rrob Posted February 13, 2011 Author Report Share Posted February 13, 2011 Cheers dudes, haven`t had a look yet but are the cables adjusted at the valve end or the motor end? Link to comment Share on other sites More sharing options...
MonkeyJim Posted February 14, 2011 Report Share Posted February 14, 2011 Monkey! I`m looking at you. Or any other twonk thats done this before.... it's nice to be asked but sorry I can't help you on this one. I only ever adjusted the exup once... and then promptly binned it in favour of a full system. but from memory, you do want a little bit of slack in the cables, don't do them ultra tight. The adjusters are at the motor end of the cables so you'll need to remove the petrol tank. Link to comment Share on other sites More sharing options...
MonkeyJim Posted February 17, 2011 Report Share Posted February 17, 2011 whilst looking for something else I found this very useful link on exup maintenance / adjustment http://www.sites4bikes.com/R1-EXUP-98-01-Adjustment.htm Link to comment Share on other sites More sharing options...
