Chrisball Posted February 7, 2011 Report Share Posted February 7, 2011 As above i have a Suzuki RGV fuel tank i need to clean the inside of, its showing some surface rust on the inside and im hoping it can be saved! ANy words of wisdom welcome. A friend says he saw an artice in classic motorcycle mechanics were they used a liquid and some old nuts and bolts?? CHeers Link to comment Share on other sites More sharing options...
ccmhunt Posted February 7, 2011 Report Share Posted February 7, 2011 Best stuff ever....LINKY:POR15 Link to comment Share on other sites More sharing options...
rossm Posted February 7, 2011 Report Share Posted February 7, 2011 Oddly enough cheap supermarket branded coke (as in the drink) Link to comment Share on other sites More sharing options...
BudgetBoy Posted February 7, 2011 Report Share Posted February 7, 2011 This is some of the things you can do. Coke (Been said) Vinegar (Mild acetic acid) Electrolysis As with anything using the above, make sure you have rinsed it well with water, than make sure you dry it out or you will be back to square one again. use Hairdryer,oven ect, just make sure its dry. Link to comment Share on other sites More sharing options...
szrdave Posted February 8, 2011 Report Share Posted February 8, 2011 As above i have a Suzuki RGV fuel tank i need to clean the inside of, its showing some surface rust on the inside and im hoping it can be saved! ANy words of wisdom welcome. A friend says he saw an artice in classic motorcycle mechanics were they used a liquid and some old nuts and bolts?? CHeers There is a guide in the most recent edition of 'Practical Sportsbikes' magazine for exactly this..... Link to comment Share on other sites More sharing options...
brad Posted February 9, 2011 Report Share Posted February 9, 2011 Hi, Rupe did a wee article in that there PB mag last month or mebe month before using home electrolysis. Brad. Link to comment Share on other sites More sharing options...
Richy Posted February 11, 2011 Report Share Posted February 11, 2011 Citrc acid works a treat. Link to comment Share on other sites More sharing options...
Ian_H Posted February 11, 2011 Report Share Posted February 11, 2011 Used this stuff a couple of times for severely rusted tanks:- Flowliner Link to comment Share on other sites More sharing options...
