EvilSpike Posted January 26, 2011 Report Share Posted January 26, 2011 Afternoon If i want to change the gearing on my 2007 ZX6R then I'm going to need a speedo healer. If i fit one of these, will the gear position indicator that comes as standard on the clocks still work correctly? Ta Spike Link to comment Share on other sites More sharing options...
MonkeyJim Posted January 26, 2011 Report Share Posted January 26, 2011 Afternoon If i want to change the gearing on my 2007 ZX6R then I'm going to need a speedo healer. If i fit one of these, will the gear position indicator that comes as standard on the clocks still work correctly? Ta Spike I don't know about the standard gear indicator, but I guess so. Presumably they work the same as the aftermarket ones, by comparing the ratio of signal pulses from the speedo and tacho [i could be wrong!]? I fitted a speedo healer to the R1 last summer, a few days before I went to Germany for a weekend. The speedo was now 100% accurate but the gear indicator [Acumen DG8] wouldn't show anything higher than 4th, even if the bike was in 5th or 6th. whilst away I reset the speedo healer back to zero, ie. no change, so at least the gear indicator worked properly. That was right at the end of the year and I haven't been out on the bike since. I think I need to set the speedo healer and then re-calibrate the gear indicator to suit. Link to comment Share on other sites More sharing options...
EvilSpike Posted January 26, 2011 Author Report Share Posted January 26, 2011 I think I need to set the speedo healer and then re-calibrate the gear indicator to suit. Hmm, would that be possible on an inbuilt system? For the record I have tried emailing HealTech, the makers of the speadohealers and asking but haven't had a reply... Link to comment Share on other sites More sharing options...
BDS Posted March 4, 2011 Report Share Posted March 4, 2011 Afternoon If i want to change the gearing on my 2007 ZX6R then I'm going to need a speedo healer. If i fit one of these, will the gear position indicator that comes as standard on the clocks still work correctly? Ta Spike Hi Spike, your factory gear indicator won't be affected by a Speedo Healer but aftermarket ones need to be re programmed after Speedo Healer has been set up. Link to comment Share on other sites More sharing options...
