Romski Posted January 25, 2011 Report Share Posted January 25, 2011 Hello out there, has anyone on here had a radiator repaired? was it any good? thanks Link to comment Share on other sites More sharing options...
Mark/Foggy Posted January 25, 2011 Report Share Posted January 25, 2011 Hello out there, has anyone on here had a radiator repaired? was it any good? thanks Yes. Link to comment Share on other sites More sharing options...
CMSMJ1 Posted January 25, 2011 Report Share Posted January 25, 2011 Me too.. Link to comment Share on other sites More sharing options...
Romski Posted January 25, 2011 Author Report Share Posted January 25, 2011 Yes. details please, like where???? merci buckets. Link to comment Share on other sites More sharing options...
CMSMJ1 Posted January 26, 2011 Report Share Posted January 26, 2011 I used Northern Radiators in Bradford. They recored a knackered NC30 lower rad for the princely sum of £160 It was screwed ...and came out thus. Link to comment Share on other sites More sharing options...
chrisexup Posted January 30, 2011 Report Share Posted January 30, 2011 i slapped a bit of quick metal on the rad when it sprung a leak. it lasted for years until i retired it. Link to comment Share on other sites More sharing options...
Mark/Foggy Posted January 31, 2011 Report Share Posted January 31, 2011 If you've punctured a rail, most alloy welders should be able to help you out. If you cut into the tanks at the sides for access, you can get the offending rail welded up from the inside. Renders a newish rad water tight again, the cut outs get welded back in afterwards. You'll lose some efficiency of course. I've only realy had this done on big race rads, so not too much of an issue if you keep an eye on things. Brad the Rad at Bora is where they usualy get done for us, since he makes them in the first place. Link to comment Share on other sites More sharing options...
