gixxerphil Posted December 6, 2008 Report Share Posted December 6, 2008 Can someone tell me what the standard gearing is on a 2007 SD. The problem i've had is that B+C said it was 17 so i bought a 16 tooth, but when i took the sprocket cover off it was fitted with a 16 tooth ktm oe sprocket, is this standard or has the previous owner already geared it. Link to comment Share on other sites More sharing options...
TKDMitch Posted December 6, 2008 Report Share Posted December 6, 2008 Can someone tell me what the standard gearing is on a 2007 SD. The problem i've had is that B+C said it was 17 so i bought a 16 tooth, but when i took the sprocket cover off it was fitted with a 16 tooth ktm oe sprocket, is this standard or has the previous owner already geared it. My early one certainly came with a 17, but I'm not 100% about the later bikes. I'm pretty sure they came with a 17, but it was very common for people to swap to a 16. superduke.net or ktmforum.co.uk would be able to tell you for sure. Mitch Link to comment Share on other sites More sharing options...
dougb Posted December 7, 2008 Report Share Posted December 7, 2008 05 and 06 models had a 17 tooth front as standard,after that they came with a 16........ Link to comment Share on other sites More sharing options...
