Babyjase Posted January 23, 2011 Report Share Posted January 23, 2011 I'll be changing the front brake pads of the blade next weekend and wondered is their a proper way to 'bed in' the brake pads? Jacobs fig rolls shall be issued for good advice! Link to comment Share on other sites More sharing options...
EXJ10R Posted January 23, 2011 Report Share Posted January 23, 2011 Just go easy for the 1st 50-75 miles, smooth application on the front lever, judging corner entry speed will help and not promote heavy braking, don't bury the front into the ground when coming up to corners, rondabouts, junctions etc etc... then after that you can use as intended. Not a fan of fig rolls though. Link to comment Share on other sites More sharing options...
BudgetBoy Posted January 23, 2011 Report Share Posted January 23, 2011 Have to aggree here. Take it nice and steady (30-50 miles) to allow the new pads to bed in with the old disc's. Link to comment Share on other sites More sharing options...
szrdave Posted January 23, 2011 Report Share Posted January 23, 2011 As above, although tbh I pretty much ride as normal after fitting new pads and have never had a problem with glazing etc. If you're fitting a different brand or compound of pad it's worth cleaning the discs up with a bit of emery paper and some brake cleaner though, before putting the new pads in. Link to comment Share on other sites More sharing options...
Egg on Leggs Posted January 23, 2011 Report Share Posted January 23, 2011 I put a 2 or three radial lines on the discs with a felt tip pen, when the marks are gone you know they have worn in. Link to comment Share on other sites More sharing options...
