Grumpyduck Posted January 15, 2011 Report Share Posted January 15, 2011 Well after stripping my recently acquired engine for gearbox bits, I decided that maybe I would do the big ends and directly transplant the refurbished engine. Upon further stripping and inspection one set of big-end shells have indeed picked up and lunched themselves making quite a mess of one of the crank journals in the process. Can anyone recommend me a good, cheap place to send the crank for regrinding..? Thanks.. Ooo pics look.. GD Link to comment Share on other sites More sharing options...
nigel.ted Posted January 15, 2011 Report Share Posted January 15, 2011 For stuff like this good & cheap dont go together These are local to me and well recommended but not cheap! http://www.sep-kegworth.co.uk/page1.htm give em a bell nigel Link to comment Share on other sites More sharing options...
Superdunc Posted January 15, 2011 Report Share Posted January 15, 2011 What Nigel said. I've used SEP when I lived down the road from them, they are very good I now use these people,http://www.ocservice.co.uk/, as they are nearer to me and probably more convinient to you too. They are also very good, plus the are right opposite Moto Rapido so you can pop in and dribble over the Ducatis when you drop your crank off. Link to comment Share on other sites More sharing options...
alexp5 Posted January 15, 2011 Report Share Posted January 15, 2011 For stuff like this good & cheap dont go together These are local to me and well recommended but not cheap! http://www.sep-kegworth.co.uk/page1.htm give em a bell nigel ^This. Definitely. Not cheap, but do you really want cheap where cranks and big end shells are concerned? Service Exchange Parts sorted my Kettle crank years ago. Link to comment Share on other sites More sharing options...
Grumpyduck Posted January 16, 2011 Author Report Share Posted January 16, 2011 Not cheap, but do you really want cheap where cranks and big end shells are concerned? I meant "relatively" cheap... some places can charge the earth and be crap.* GD *ask me how I know.. Link to comment Share on other sites More sharing options...
lorenzo Posted January 16, 2011 Report Share Posted January 16, 2011 pop and dribble over the Ducatis when you drop your crank off. I've never heard 'drop your crank off' used as a euphamism before. Link to comment Share on other sites More sharing options...
margrit Posted January 16, 2011 Report Share Posted January 16, 2011 Have you checked the size of the current bearings and compared the current size with the manual to see how much material can be ground off the journal with the range of thicker bearing shells available? Worth doing before you spend money and get the crank re-ground and then find you can't get the right bearing clearance....... Edit - d'oh, millemille; posting on t'waifes laptop. Link to comment Share on other sites More sharing options...
Grumpyduck Posted January 16, 2011 Author Report Share Posted January 16, 2011 Have you checked the size of the current bearings and compared the current size with the manual to see how much material can be ground off the journal with the range of thicker bearing shells available? Worth doing before you spend money and get the crank re-ground and then find you can't get the right bearing clearance....... I haven't but they are the OEM fittings, engine has only 15000mls on it. So should be OK.. I will check though.. GD Link to comment Share on other sites More sharing options...
thefatman Posted January 16, 2011 Report Share Posted January 16, 2011 Wouldn't it be easier to buy a crank from a breaker which is in good condition, then stick with standard shells. Link to comment Share on other sites More sharing options...
