Gregorious77 Posted December 29, 2010 Report Share Posted December 29, 2010 The time has come to service my G2 ZX6R and the clearances need checking on this one. I dont have a problem with doing them but I do have 1 question. Where is the best place to get Kawasaki shims? my local bike shops are shite so I am not even going to bother and the nearest Quack dealer to me is a fair way away. The bike is off the road for the winter so I may as well order online. 14 out of 16 are out of spec (all too tight) and out of the 2 that are in spec 1 is bang on the lower limit. I am going to replace the shim for one that takes it to the middle of the limit. I have not taken the cams off yet so not sure what shims i can move about and what I need to get. This does confirm my suspicions that the local bike shop didnt even check the clearances the last time they were due which is why I always do my own servicing and repairs. Link to comment Share on other sites More sharing options...
fran9r Posted December 29, 2010 Report Share Posted December 29, 2010 If you need a few: http://www.maxmx.co.uk/productdetail.html?ID=3663 Link to comment Share on other sites More sharing options...
Gregorious77 Posted December 29, 2010 Author Report Share Posted December 29, 2010 If you need a few: http://www.maxmx.co.uk/productdetail.html?ID=3663 Looks good 5 of each size! looks like you get 1.80, 1.85, 1.90, 1.95, 2.00, 2.05 Link to comment Share on other sites More sharing options...
ronenige Posted December 30, 2010 Report Share Posted December 30, 2010 Make sure you get the right ones http://www.maxmx.co.uk/listproduct.html?catID=539 are listed as kawasaki , best thing is make a note of your clearances , cable tie the cam chain to the pulleys , remove the tensioner and remove the cams , measure the od of the shims to make sure your getting the correct fella's , be very careful when re-assembling to make sure the carrier goes down parallel to the head , all of the bolts 1 turn at a time , I've heard of people cracking them Link to comment Share on other sites More sharing options...
Gregorious77 Posted December 31, 2010 Author Report Share Posted December 31, 2010 Make sure you get the right ones http://www.maxmx.co.uk/listproduct.html?catID=539 are listed as kawasaki , best thing is make a note of your clearances , cable tie the cam chain to the pulleys , remove the tensioner and remove the cams , measure the od of the shims to make sure your getting the correct fella's , be very careful when re-assembling to make sure the carrier goes down parallel to the head , all of the bolts 1 turn at a time , I've heard of people cracking them I have now measured the shims and setup a spreadsheet with clearances and shim sizes then worked out what can be swapped about which left only 6 to buy. Got some ordered off ebay for 14 quid. I will be careful on reassembly as I have heard of people snapping camshafts!! I have done cam work before even though it was a mk2 golf. Why do you cable tie the chain onto the pulleys? I just tied some wire round it to stop it falling down into the case. Link to comment Share on other sites More sharing options...
ronenige Posted January 1, 2011 Report Share Posted January 1, 2011 Why do you cable tie the chain onto the pulleys? I just tied some wire round it to stop it falling down into the case. stops the timing moving Link to comment Share on other sites More sharing options...
