roastdinajima Posted December 27, 2010 Report Share Posted December 27, 2010 I've replaced the knackered rear shock on my '00 zx6r track bike with a stock one from another bike, before i can set the sag/preload i need to get the rear ride height done this is easily adjustable but what should it be set at as standard? and where is it best to measure it from/to? Cheers Link to comment Share on other sites More sharing options...
Gregorious77 Posted December 27, 2010 Report Share Posted December 27, 2010 easy to adjust there is an adjuster nut and locknut on the bottom of the shock. No idea what you would set it to for the track but I raised the rear on my 99 G2 5mm at the shock which gives about 25mm total I think. Found this PDF Link to comment Share on other sites More sharing options...
lorenzo Posted December 27, 2010 Report Share Posted December 27, 2010 Might be some decent info in this little lot. Link to comment Share on other sites More sharing options...
roastdinajima Posted December 27, 2010 Author Report Share Posted December 27, 2010 Thanks but that tells me to raise it from standard to help turn in, but doesn't tell me what it should be set to as a standard to work from. How much thread should i have below the lock nut on the shock bracket where it bolts to the frame. edit to add photo Link to comment Share on other sites More sharing options...
Gregorious77 Posted December 28, 2010 Report Share Posted December 28, 2010 Thanks but that tells me to raise it from standard to help turn in, but doesn't tell me what it should be set to as a standard to work from. How much thread should i have below the lock nut on the shock bracket where it bolts to the frame. edit to add photo According to the article +8mm is your setting and standard is 0mm so no thread showing as standard. Click to see a bigger pic. Link to comment Share on other sites More sharing options...
