paul8899 Posted December 1, 2010 Report Share Posted December 1, 2010 I am thinking of making an offset front sprocket but I am unsure as to which material to use. I have seen that they are normally about hardened to 35rc so are they made out of tool steel or are they case hardened mild steel ? Link to comment Share on other sites More sharing options...
alexp5 Posted December 2, 2010 Report Share Posted December 2, 2010 Renthal say: 'RENTHAL front sprockets are made from case hardened and core refined 655M13 Nickel Chrome Molybdenum alloy steel to give the ultimate combination of strength and hardness.' These folks can sort out offset sprockets: http://www.powerlinks.co.uk/sprockets.html Don't know if this is of any use to you? Link to comment Share on other sites More sharing options...
2moto Posted December 2, 2010 Report Share Posted December 2, 2010 I just got one off Talon Engineering. £45 and took 3 weeks. Link to comment Share on other sites More sharing options...
Tomfoolery Posted December 2, 2010 Report Share Posted December 2, 2010 B&C Express can help you too, with material information if you don't want to buy one. Link to comment Share on other sites More sharing options...
paul8899 Posted December 2, 2010 Author Report Share Posted December 2, 2010 Cheers , I'll give B+C a call and let you all know what they say . I found a neat little program that outputs a Gcode program for sprockets. All you have to do is put the chain width and required teeth and it outputs the profile program. I'll give it a go in a couple of weeks. Its called sprocketeer Link to comment Share on other sites More sharing options...
