jaycee Posted November 28, 2010 Report Share Posted November 28, 2010 Can someone please tell me what the fuck I am doing wrong? Apart from stripping the fucking carbs off in the first place!!! Carbs have been carefully cleaned and put back together. Unfortunately, the photos I took during the strip don't show how the throttles are supposed to link when you put them back together again. The workshop manual basically just says, put them back together. The following images show my problem The 2 flanges are supposed to interlink somehow, but I can't get this to happen without causing the spring to either get caught up, crushed or merely just ping underneath the workbench. Obviously I have to do the same with the other pair of carbs. What the hell am I missing? Link to comment Share on other sites More sharing options...
Kayla Posted November 28, 2010 Report Share Posted November 28, 2010 Can someone please tell me what the fuck I am doing wrong? Apart from stripping the fucking carbs off in the first place!!! Carbs have been carefully cleaned and put back together. Unfortunately, the photos I took during the strip don't show how the throttles are supposed to link when you put them back together again. The workshop manual basically just says, put them back together. The following images show my problem The 2 flanges are supposed to interlink somehow, but I can't get this to happen without causing the spring to either get caught up, crushed or merely just ping underneath the workbench. Obviously I have to do the same with the other pair of carbs. What the hell am I missing? I think, and I could be wrong, that the flanges don't actually touch. The top pic shows two springs- will the flange on the lower pic sit between the right hand spring and left hand flange (upper pic)? Sorry, it's not very easy to explain what I mean, but I think the right hand spring in the upper pic separates the two flanges- the screw in the upper pic is used to synchronise the butterflies together by preloading the spring on the right in the upper pic. Is there a witness mark on the flange in the lower pic where the screw might have been turned against? Link to comment Share on other sites More sharing options...
jaycee Posted November 28, 2010 Author Report Share Posted November 28, 2010 I think that the springless tab is supposed to get between the screw and the spring on the other tab, its just achieving this while pressing the 2 carbs together and holding the spring in place with only 2 hands and not enough space for 2 people. Link to comment Share on other sites More sharing options...
Kayla Posted November 28, 2010 Report Share Posted November 28, 2010 I think that the springless tab is supposed to get between the screw and the spring on the other tab, its just achieving this while pressing the 2 carbs together and holding the spring in place with only 2 hands and not enough space for 2 people. That's what I meant, in about a quarter of the space I took up! Can you remove the screw (or at least back it right off) so you've got more room to move? Link to comment Share on other sites More sharing options...
spacemonkey Posted November 28, 2010 Report Share Posted November 28, 2010 This would be a normal tongue and yoke arrangement. I think you'll find the tongue goes betweent the end of the screw and the spring so you can synchronise each carb. Link to comment Share on other sites More sharing options...
chrisexup Posted November 28, 2010 Report Share Posted November 28, 2010 a set of YZF750 carbs, this afternoon... Link to comment Share on other sites More sharing options...
krazyk Posted November 28, 2010 Report Share Posted November 28, 2010 a certain cure for Honda problems http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...e=STRK:MEWAX:IT Link to comment Share on other sites More sharing options...
Kayla Posted November 28, 2010 Report Share Posted November 28, 2010 a set of YZF750 carbs, this afternoon... Woo! Link to comment Share on other sites More sharing options...
jaycee Posted November 29, 2010 Author Report Share Posted November 29, 2010 a certain cure for Honda problems http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...e=STRK:MEWAX:IT Cheers Keith, can you give me £1200 please? I'll give you a FireBlade and a set of carbs in return Link to comment Share on other sites More sharing options...
jaycee Posted November 29, 2010 Author Report Share Posted November 29, 2010 a set of YZF750 carbs, this afternoon... That looks like it. I think I'll measure up the screw with my Vernier then turn it right back. I don't want to mess up any setting if I can help it. Cheers guys Link to comment Share on other sites More sharing options...
