wazrs257 Posted November 27, 2010 Report Share Posted November 27, 2010 I'm trying to find a cheaper alternative to genuine head o-rings for my Rotax 250. There are two sealing the water jacket, the inner one's easy because it's a standard size (I've already got a dozen of those), but the outer one isn't & Rotax want £6.88 plus vat each. I had intended to buy a few to keep in stock, but not at that price! Its 129mm diameter and 2.5mm cross section. Any ideas? I've seen kits where you buy a lenght of the correct cross section 'rubber' and join it with a special glue, would these be suitable for sealing the waterjacket? Link to comment Share on other sites More sharing options...
spacemonkey Posted November 27, 2010 Report Share Posted November 27, 2010 I'm trying to find a cheaper alternative to genuine head o-rings for my Rotax 250. There are two sealing the water jacket, the inner one's easy because it's a standard size (I've already got a dozen of those), but the outer one isn't & Rotax want £6.88 plus vat each. I had intended to buy a few to keep in stock, but not at that price! Its 129mm diameter and 2.5mm cross section. Any ideas? I've seen kits where you buy a lenght of the correct cross section 'rubber' and join it with a special glue, would these be suitable for sealing the waterjacket? http://www.epm.com/metric_chart3.htm Link to comment Share on other sites More sharing options...
wazrs257 Posted November 27, 2010 Author Report Share Posted November 27, 2010 Brilliant thanks, all the size charts I've seen have been in imperial! Link to comment Share on other sites More sharing options...
spacemonkey Posted November 27, 2010 Report Share Posted November 27, 2010 Brilliant thanks, all the size charts I've seen have been in imperial! Sweet, I haven't used them before mind but I presume it means the one you want is an off the shelf item.... Shame they don't list the 1.8mm x 109mm oring that I want! Link to comment Share on other sites More sharing options...
blow_away Posted November 27, 2010 Report Share Posted November 27, 2010 I can't find it on their website, but BSL sell "O ring cord" in 0.5mm increments http://www.brammer.co.uk/uk/o_rings.aspx I used some 2.5mm to replace the float bowl seals on the Team South bike. I used el cheapo superglue to hold the ends down. Keep an eye on the Team South thread to see if it works Link to comment Share on other sites More sharing options...
wazrs257 Posted November 27, 2010 Author Report Share Posted November 27, 2010 I've e-mailed these guys for a price for 10off, will let you know when they get back to me. http://www.epm.com/metric_chart3.htm Brammer will get a call if that doesn't work out price wise. On a slight side note, I've just come accross a mega tuned top end for my 257, so if I can get the o-rings sorted, it'll be fitted before I book it in to be dyno'd. Edited for crap, slightly tipsy grammer! Link to comment Share on other sites More sharing options...
Sean Posted November 27, 2010 Report Share Posted November 27, 2010 Where i get mine from http://www.polymax.co.uk/acatalog/O-Rings_...ection_NBR.html Link to comment Share on other sites More sharing options...
r3rsv Posted December 5, 2010 Report Share Posted December 5, 2010 Hi just a quick one about o rings, its a standard emergency procedure in the oil industry to cut and superglue 'o' rings together. Ihave done it 100s of times in training schools and demonstrations then pressure tested up-to 10k psi. Just make a nice clean square cut with new stanley blade add one very small blob of superglue to one end and line up then push together blow on it while still pushing together about 15 secs and walla there you go. It just takes a bit of practice lining them up between your forefingers and thumbs. Good luck if i get time i will make a short video if anybody is interested. Link to comment Share on other sites More sharing options...
wazrs257 Posted December 5, 2010 Author Report Share Posted December 5, 2010 EPM havn't bothered getting back to me with a price, bloody americans! Polymax do them for 41p each, so I think I'll order a dozen of those. It'll still work out cheaper than one genuine Rotax o-ring! Thanks for the replies guys. Link to comment Share on other sites More sharing options...
