Bernster Posted November 23, 2010 Report Share Posted November 23, 2010 I need the existing lock stop's machining away, (including the barely existing one) - and a couple of aluminium replacements making with a sunken head for around a 6mm or 8mm allen bolt to bolt them onto the yoke with. Possibly be handy to have a spare couple of additional replacement lock stop's made in case this happens again while the replacements are being made. I can drill and tap the yoke to get them fitted. Drop me a PM if you accept the challenge. See images below: Link to comment Share on other sites More sharing options...
will#224 Posted November 23, 2010 Report Share Posted November 23, 2010 Probably not a solution but a lot of racers are now using nylon sleeves around the forks that bump into the frame if you reach the steering lock. Might be worth a look and might be cheaper? Link to comment Share on other sites More sharing options...
Kayla Posted November 23, 2010 Report Share Posted November 23, 2010 I can do it. Dunno if it'd be worth your while once you've paid for post here and back though- maybe get a local firm to do the milling? I can certainly make you a few sets of ally stops counterbored for an M6 or M8 allen bolt cheap enough. Link to comment Share on other sites More sharing options...
Bernster Posted November 23, 2010 Author Report Share Posted November 23, 2010 I can do it. Dunno if it'd be worth your while once you've paid for post here and back though- maybe get a local firm to do the milling? I can certainly make you a few sets of ally stops counterbored for an M6 or M8 allen bolt cheap enough. Thanks for responding, I don't mind paying for the cost of getting it to you if you can get it securely packaged and shipped back? (obviously I’ll cover the cost of that postage too). Does your milling setup have the ability to get into the tricky bit without hitting the fork leg clamps as they are proud and the stem in the centre protrudes proud too, (might need pressing out). There's a local engineer but he's never there so I'm afraid to take it to him in case I never see it again as it's not a cheap cast bottom yoke. PM if you have an idea of price. *edit iPhone .. meh! Link to comment Share on other sites More sharing options...
ricey3 Posted November 23, 2010 Report Share Posted November 23, 2010 i can mill off the lock stops if you want and press the stem in and out. I'm at derby. cheers Link to comment Share on other sites More sharing options...
kaighn80 Posted November 24, 2010 Report Share Posted November 24, 2010 any one in essex that can do machining? i have a sprocket carrier that needs attention. Link to comment Share on other sites More sharing options...
eddie Posted November 26, 2010 Report Share Posted November 26, 2010 Hi I can/could, but I'm in Hants Paul Link to comment Share on other sites More sharing options...
