geoffmm Posted November 23, 2010 Report Share Posted November 23, 2010 Easy question chaps and ladies. I will be changing the rear sprocket on my R1 and assume that i should use some sort of thread sealant when re torquing the nuts back up, question is, Which is the best one to use? Link to comment Share on other sites More sharing options...
eddie Posted November 23, 2010 Report Share Posted November 23, 2010 Loctite (or similar), threadlock or nutlock will do, just make sure the threads are clean (we use a solvent spray at work to clean the threads first) Paul Link to comment Share on other sites More sharing options...
geoffmm Posted November 23, 2010 Author Report Share Posted November 23, 2010 great advice, thanks Link to comment Share on other sites More sharing options...
MonkeyJim Posted November 24, 2010 Report Share Posted November 24, 2010 Loctite (or similar), threadlock or nutlock will do, just make sure the threads are clean (we use a solvent spray at work to clean the threads first) Paul I use this one on the bike it's a few quid from Halfrauds and tube last for ages Link to comment Share on other sites More sharing options...
Evilchicken0 Posted November 26, 2010 Report Share Posted November 26, 2010 You need loctite BLUE. You should know that loctite red is permanant and so you'll end up breaking the studs when you try to take the nuts off next time. Ask Karla about it's use on a front wheel Link to comment Share on other sites More sharing options...
geoffmm Posted December 3, 2010 Author Report Share Posted December 3, 2010 Loctite blue is what i got and it seems to be doing the job. thanks for all your advice guys and gals. Link to comment Share on other sites More sharing options...
sjbmotorcycles.co.uk Posted December 3, 2010 Report Share Posted December 3, 2010 Any brand of threadlock will do but be carefully as loctite do a bearing compound n you'll never get it undone again think it's the yellow one go for the blue stuff Link to comment Share on other sites More sharing options...
