Bernster Posted November 21, 2010 Report Share Posted November 21, 2010 I'm trying to save a vast amount of money during the wheel building part of my Yamaha WR450 Supermoto conversion by utilising Suzuki DRZ wheels as for some reason they seem to be a lot cheaper to buy, (presumably as so many are in SM trim from the factory). So I'm looking at the total hassle / cost of getting spacers, possible hub machining and that kind of thing to get them to fit versus laying out the full cost of getting a WR450 specific wheel set. I know the DRZ run's the same 20mm front / rear axle so it's a case of lining up the sprocket, discs etc and getting adapters made to run a larger disk up front. Does anyone know a good contact that I could use to get parts machined etc preferable in The Midlands area. Relates to: >>PB Post<< Link to comment Share on other sites More sharing options...
jaycee Posted November 21, 2010 Report Share Posted November 21, 2010 KAYLA !!! Link to comment Share on other sites More sharing options...
Hendo Posted November 21, 2010 Report Share Posted November 21, 2010 eddie of this parish is shit hot at this sort of thing aswell. Andy Link to comment Share on other sites More sharing options...
Fino Posted November 21, 2010 Report Share Posted November 21, 2010 Try Paul at: Charter Precision Engineering 01527584187 Unit 25-26, Enfield Industrial Estate, REDDITCH, B97 6BY He's done a few decent jobs for me over the past couple of years for beer money. Link to comment Share on other sites More sharing options...
ricey3 Posted November 22, 2010 Report Share Posted November 22, 2010 i could do you bits depending on what you want, I've only got a small CNC mill so wouldn't be able to mill a wheel but bits and bobs and stuff on the lathe no problem Link to comment Share on other sites More sharing options...
Kayla Posted November 22, 2010 Report Share Posted November 22, 2010 If the wheel spindles are the same sizes then all you need to do is get the wheels central and measure up for spacers either side. Once the wheel is central and you've got a disc sorted out, it's then a case of getting the caliper to fit. Depending on the caliper you might need to space the disc out a little. I'd bet that the sprocket offsets aren't a million miles away though. Link to comment Share on other sites More sharing options...
