tonk Posted November 3, 2010 Report Share Posted November 3, 2010 Anyone ever fitted a shift light? I fancy one on my bike, I'm bouncing it off the limiter too often - can't hear well enough above a certain speed and the numbers are a bit diddy. It all goes a bit too wobbly to use peripheral vision. Rode a bike with one the other day and was very impressed. Any suggestions for make/model? Link to comment Share on other sites More sharing options...
MonkeyJim Posted November 4, 2010 Report Share Posted November 4, 2010 I've got an Acumen PD8 one fitted to the R1. http://www.acumen-electronics.co.uk/catego...ft_light,b.html It was a piece of piss to fit as I got the 'plug & play' version which connects onto the same bespoke loom as the DG8 gear indicator. It's easy to [re]program and can be set up to light up in various different ways, starting and ending at whatever revs you want. Link to comment Share on other sites More sharing options...
madmike Posted November 4, 2010 Report Share Posted November 4, 2010 That looks really good! I'm very tempted tbh! Link to comment Share on other sites More sharing options...
gsxr renegade Posted November 4, 2010 Report Share Posted November 4, 2010 Yep, came as standard on my old 750. I didn't really rely on it much to be honest, it was normally fairly obvious when i should change gear. Quite useful on track though, when i had earplugs in and couldn't hear the exhaust, so that i knew if i had any more revs left, or if i needed to change gear. Link to comment Share on other sites More sharing options...
rossm Posted November 4, 2010 Report Share Posted November 4, 2010 I've got an Acumen PD8 one fitted to the R1. http://www.acumen-electronics.co.uk/catego...ft_light,b.html It was a piece of piss to fit as I got the 'plug & play' version which connects onto the same bespoke loom as the DG8 gear indicator. It's easy to [re]program and can be set up to light up in various different ways, starting and ending at whatever revs you want. Got one as standard on the '02s onwards Link to comment Share on other sites More sharing options...
tonk Posted November 5, 2010 Author Report Share Posted November 5, 2010 Thanks guys, can't see any pictures at work but I'll have a look next week. How would it wire in if I couldn't 'plug and play'? The bike has a CAN BUS system. Link to comment Share on other sites More sharing options...
trackdaybob Posted November 5, 2010 Report Share Posted November 5, 2010 Translogic do a one. I had one on my R1 and it worked great and was easy to wire in. Link to comment Share on other sites More sharing options...
tonk Posted November 5, 2010 Author Report Share Posted November 5, 2010 Can't find anything on the translogic website, just the shift-light cluster as a spare part with no info at all. Looks a bit nicer than the acumen though... Link to comment Share on other sites More sharing options...
Gpz1100_Convert Posted December 10, 2010 Report Share Posted December 10, 2010 dyna shift lights are fairly easy to fit and often come up on ebay cheap as chips. It is where I got mine Mark Link to comment Share on other sites More sharing options...
