Tom Mac Posted November 28, 2008 Report Share Posted November 28, 2008 My commuter hack has a set of oxford heated grips on it (fitted by a previous owner) which I've used for the first time this morning..... all was good for a few miles, toasty warm palms but then the throttle tube seemed to the rotating back under the grip which resulted in me gripping the tube tighter than a S&M bloke grips his c*ck during a frantic flap, just to keep the damn thing going. I'm assuming the "glue" holding the heated grip on is past its best but do I need to use a specific "oxford" glue or will something else do? Link to comment Share on other sites More sharing options...
jayRC3045 Posted November 28, 2008 Report Share Posted November 28, 2008 my viffer had heated grips on when i got it , and the throttle use to stick ,i just cut a little bit of the grip away where it was rubbing on the bar end job done edit ,as am still asleep ,i just read your post again and my answer has fook all to do with your problem but if anyone has probs with heated grips and sticking throttle see above for advice lol Link to comment Share on other sites More sharing options...
David W Posted November 28, 2008 Report Share Posted November 28, 2008 I always use contact cleaner or brake cleaner, etc to fit grips. That evo-stick stuff fails eventually. Link to comment Share on other sites More sharing options...
Tom Mac Posted November 28, 2008 Author Report Share Posted November 28, 2008 oh wonderful, I'll try regluing them and I suppose i'll be saving up for somw better gloves then Link to comment Share on other sites More sharing options...
Tomfoolery Posted December 4, 2008 Report Share Posted December 4, 2008 I've used hairspray on all the grips I've fitted and it's worked wonders. Link to comment Share on other sites More sharing options...
Mr.Pigdog Posted December 4, 2008 Report Share Posted December 4, 2008 I always use araldite-fair enough when it comes time to replace them i have to grind the old stuff away but i found renthal grip glue just softens up when they get hot.Reckon oxford are one of the better brands of heated grips too. Link to comment Share on other sites More sharing options...
