lorenzo Posted October 23, 2010 Report Share Posted October 23, 2010 I'm after a nifty built in reservoir type master cylinder, most likely off a fairly recent crosser. However, none of the adverts on ebay have the mounting sizes listed. I need one that's 45mm between the holes, anybody got a modern crosser in the shed and can get the ruler out for me? Link to comment Share on other sites More sharing options...
stuntmonkee Posted October 23, 2010 Report Share Posted October 23, 2010 Got one on my CRF450, I'll pop out and measure in a bit Link to comment Share on other sites More sharing options...
scrappy600 Posted October 23, 2010 Report Share Posted October 23, 2010 Got one on my CRF450, I'll pop out and measure in a bit CRF rear master is 53.58mm from bottom of bottom holt to top of top hole. to center of each is 48.7+/- Link to comment Share on other sites More sharing options...
stuntmonkee Posted October 23, 2010 Report Share Posted October 23, 2010 Saves me a trip Link to comment Share on other sites More sharing options...
sennidott Posted October 23, 2010 Report Share Posted October 23, 2010 Nissin master cylinder from an RMZ250. Mounting points: 36mm centres 1/2 inch bore. That's probably not going to be of much use to you... Link to comment Share on other sites More sharing options...
lorenzo Posted October 24, 2010 Author Report Share Posted October 24, 2010 Hmm, thanks very much, I'll keep mooching about looking to see what might fit. Link to comment Share on other sites More sharing options...
Cibbersicks Posted October 24, 2010 Report Share Posted October 24, 2010 I had to modify my rearsets on the trackbike to accommodate the CRF m/c, but also, when mating it with a larger (than an mx) rear caliper it was an absolute bastard to bleed, a mityvac still suffered to get it right, I had to upgrade mine using one of these: Rear Brake Return Spring While you're at it get an anodised ally cap like mine - just because Link to comment Share on other sites More sharing options...
lorenzo Posted October 24, 2010 Author Report Share Posted October 24, 2010 There's not a massive amount of meat on the rearsets for me to be able to squeeze a different size on there. It's annoying, the one on my SRAD is a perfect fit, but I don't want to have a reservoir dangling off somewhere. I might just have to do my own version of the HRC reservoir with a bit of tubing. As for bleeding it and hydraulic ratios: it's only a rear, it doesn't need to actually work or anything... Editted to add: there's not going to be any anodised bling on this bike, although I quite like the idea of getting things anodised black. Not red, that's a girls colour, especially when it fades and goes pink. You big homo. Link to comment Share on other sites More sharing options...
Cibbersicks Posted October 26, 2010 Report Share Posted October 26, 2010 it's only a rear, it doesn't need to actually work or anything... My sentiment indeed... Editted to add: there's not going to be any anodised bling on this bike, although I quite like the idea of getting things anodised black. Not red, that's a girls colour, especially when it fades and goes pink. You big homo. I bought mine because the standard cap is cast ally and it cracked due to my cack-handidness, and secretly I chose red cos I hoped it would change to pink... Link to comment Share on other sites More sharing options...
IforB Posted October 27, 2010 Report Share Posted October 27, 2010 I'll check the ones on my YZ tomorrow. Link to comment Share on other sites More sharing options...
IforB Posted October 28, 2010 Report Share Posted October 28, 2010 Sorry Lorenzo, I ran out of time to do it today. Link to comment Share on other sites More sharing options...
lorenzo Posted October 29, 2010 Author Report Share Posted October 29, 2010 Don't worry about it, I've had a few responses now from various sellers on ebay, it seems that there's none that are even a similar size to what i need, so I'm going with a good old fashioned reservoir, or maybe a HRC-esque bit of hose. Thanks all the same. Link to comment Share on other sites More sharing options...
IforB Posted November 1, 2010 Report Share Posted November 1, 2010 No probs. Hope you get it sorted out. Link to comment Share on other sites More sharing options...
