Mohawk Posted October 13, 2010 Report Share Posted October 13, 2010 Hi Guys, I always try to sort stuff myself, but for my next trick I need some CNC or very accurate lathe work doing. I need a brake disc centering spacer to allow a narrow hub wheel to take my brake disc's & to have the disc carrier drilled to match the new PCD of the new wheel. The alternative is a custom disc carrier, but I'd expect that to be more expensive. Can anyone recommend an alloy grade for this ? What grade are disc carriers made from ? the same would be fine for this part. Can anyone recommend anywhere that can do that kind of work for real world money ? Don't mind if they are not local, so long as they are good to work with & deliver in a reasonable time. Thanks Chris. Link to comment Share on other sites More sharing options...
TriGGer Posted October 13, 2010 Report Share Posted October 13, 2010 Anyone with a lathe/miller and half a brain can sort this for you m8. Any decent spec aluminium alloy will do. (a billet or plate in the size you require will be anyway normally) The hole pitching around a set PCD is a simple calculation and can be done on a basic milling machine. Any decent local machine shop should piss this for you. HTH Link to comment Share on other sites More sharing options...
Mohawk Posted October 14, 2010 Author Report Share Posted October 14, 2010 Thanks Trigger, as I don't know any local machine shops, I was hoping someone would make a recommendation ! Any of the places I used to know would suck their teeth & provaricate if you mentioned brakes ! Link to comment Share on other sites More sharing options...
blow_away Posted October 14, 2010 Report Share Posted October 14, 2010 Give us a try Bolwell & Rowcliffe 54 - 56 Brigstocke Road St Pauls Bristol BS2 8TY Ask for Fred Link to comment Share on other sites More sharing options...
Mohawk Posted October 15, 2010 Author Report Share Posted October 15, 2010 Thanks blow_away, I've sent you an email to the company address with CAD drawings. Link to comment Share on other sites More sharing options...
eddie Posted October 17, 2010 Report Share Posted October 17, 2010 If you get stuck pm me Paul Link to comment Share on other sites More sharing options...
Hendo Posted October 17, 2010 Report Share Posted October 17, 2010 ^^^^^ I can vouch for eddies work, he made the exact same thing for me that you are after. Awesome. ^^^^^ Link to comment Share on other sites More sharing options...
