johnny Posted September 19, 2010 Report Share Posted September 19, 2010 I've gone and bought myself an electric impact wrench for changing my chain and sprockets and just thought I'd check on the correct way of using it. With the bike up on a paddock stand ready to loosen the front sprocket nut should it be in neutral, in gear, back brake on/off? I was going to do this on my own tomorrow but if the rear brake needs to be applied I would need to get the Mrs involved this afternoon. From what I gather from a bit of googling I should be alright in neutral and the wrench sorts it out but thought I'd get a second opinion on here. Many thanks. Link to comment Share on other sites More sharing options...
speedy sie Posted September 19, 2010 Report Share Posted September 19, 2010 if its powerfull enough it sould undo it in nutral,if not drop the bike on to its standleave it in nutral and the bikes wheight will hold the the chaine if this does not work,then get some one to aply the rear break. hope this helps Link to comment Share on other sites More sharing options...
johnny Posted September 19, 2010 Author Report Share Posted September 19, 2010 All done. Got the Mrs to sit on the bike with all the brakes on while I attacked the nut. Took a few goes with the wrench to get the sucker off. Either I was being too ginger or it was done up to about 500nm, probably a bit of both. All sorted now for a new chain and sprocket sometime this week. Link to comment Share on other sites More sharing options...
