Bigspud Posted September 17, 2010 Report Share Posted September 17, 2010 Just been given a scooter (03 plate Suzuki Hokuto 110cc if it makes a difference) Now, thing is it hasn't run for about 2 years, but has been stored in a garage. Here are the facts: 1. I think the engine isn't seized, as it turns over with the kickstart 2. I haven't tried to start it yet (charging the battery), but apparently it doesn't I don't know anything about either scooters or two strokes, but have put together the following list of jobs to do: 1. Make sure petrol hasn't gone off, clean / flush as required 2. Check oil 3. Oil & Filter change 4. Check / clean spark plug 5. Stand well back and push starter with broom handle Are there any recommendations for things to add or remove from the list from people who have a clue? Link to comment Share on other sites More sharing options...
Hendo Posted September 17, 2010 Report Share Posted September 17, 2010 There will be no engine oil/filter to change if its a 2 stroke! Do CVT transmissions carry any oil? Andy Link to comment Share on other sites More sharing options...
Gregorious77 Posted September 17, 2010 Report Share Posted September 17, 2010 take carb fuel bowl off and clean out the 2 stroke oil. unless its oil injection not premix. Link to comment Share on other sites More sharing options...
Kawasakifreak Posted September 17, 2010 Report Share Posted September 17, 2010 Just been given a scooter (03 plate Suzuki Hokuto 110cc if it makes a difference) Now, thing is it hasn't run for about 2 years, but has been stored in a garage. Here are the facts: 1. I think the engine isn't seized, as it turns over with the kickstart 2. I haven't tried to start it yet (charging the battery), but apparently it doesn't I don't know anything about either scooters or two strokes, but have put together the following list of jobs to do: 1. Make sure petrol hasn't gone off, clean / flush as required 2. Check oil 3. Oil & Filter change 4. Check / clean spark plug 5. Stand well back and push starter with broom handle Are there any recommendations for things to add or remove from the list from people who have a clue? The crank runs in engine oil (10W40 ?) - look for a sump drain plug to change it. Link to comment Share on other sites More sharing options...
kevin..in Posted September 18, 2010 Report Share Posted September 18, 2010 drive belt and rollers probably need a change too, belt is most probably perrished from being left standing, change it now to avoid a long push home when it snaps isn't Hokuto japanese for head north (or something similar)? Link to comment Share on other sites More sharing options...
