ninjapig Posted September 16, 2010 Report Share Posted September 16, 2010 I have got a Kawasaki ZX636 C1. The exhaust valve stops working from time to time causing the FI light to come on. The bike has done mostly dry miles, 25,000 to be more accurate, kept in a garage at nights. The problem seemed to start when i was away training for a week and had to leave the bike outside in the rain . My question is can the water get into the electrics ?. The servo motor still works because if it didnt it would stop altogether like a light bulb. Same with the valve because its mechanical i would expect it to go gradually instead of just stopping?. Any body got any ideas! Link to comment Share on other sites More sharing options...
Mr.Pigdog Posted September 16, 2010 Report Share Posted September 16, 2010 Its a common problem my friend!you cannot strip the valve to lube it either!DO NOT unscrew the servo pulley without holding it still with grips as the cogs inside easily break(thin plastic).So your choices are...use this as an excuse to replace with a performance tailcan,saturate the valve with penetrating oil and hope for the best or get onto akraprovic as i believe they used to sell a small metal arm that tricks the servo into thinking its connected(it restricts the movement) Link to comment Share on other sites More sharing options...
ninjapig Posted September 17, 2010 Author Report Share Posted September 17, 2010 Thanks friend i had an idea that i might have to get a tailcan.Shame they cant build a exhaust valve like Yamaha that can be stripped down! Link to comment Share on other sites More sharing options...
