peter30 Posted November 21, 2008 Report Share Posted November 21, 2008 My old bus (99 R1)is not feeling well and has taken to the odd big backfire when you roll off and then back on the power and a bit of fluffiness/miss on part throttle. I'm fed up of using big handfulls of throttle and generally abusing speed limits to clear its throat again and the miss doesn't help in mid corner either, so any help is appreciated. All electric plugs and conectors have been cleaned up, no sign of corrosion on them. Plugs swap and carbs clean up are my next options,unless the wise sages on here have some other ideas to help. Last service was 3,000 miles ago and I've used the bike most days, all weather conditions, mainly for the commute to work. Link to comment Share on other sites More sharing options...
banoffee Posted November 22, 2008 Report Share Posted November 22, 2008 is it stock or modified? specifically can/filter and been rejetted or not? Link to comment Share on other sites More sharing options...
peter30 Posted November 22, 2008 Author Report Share Posted November 22, 2008 is it stock or modified? specifically can/filter and been rejetted or not? standard bar end can, didn't need a rejet when last on a dyno. Link to comment Share on other sites More sharing options...
lorenzo Posted November 22, 2008 Report Share Posted November 22, 2008 Air leak on the exhaust? Either that or a clean out of the carbs and check the floats. Link to comment Share on other sites More sharing options...
2 smokes 4 ever Posted November 23, 2008 Report Share Posted November 23, 2008 backfire is classic sign of air leak either in the exhaust or round the carbs etc (airbox boot to carb, carb to head boot) Link to comment Share on other sites More sharing options...
SamB Posted November 30, 2008 Report Share Posted November 30, 2008 My Daytona used to do this. Turned out to be a small crack in the airbox. Link to comment Share on other sites More sharing options...
kwakbiker Posted December 1, 2008 Report Share Posted December 1, 2008 Id go with airleak too, rubbers on the carbs may have hardened with age and started to perish Link to comment Share on other sites More sharing options...
stretch Posted December 4, 2008 Report Share Posted December 4, 2008 a mechanic once showed me the airleak detection method- run the bike and while running, spray carb cleaner at any suspect spots-carb to intake rubbers, etc and you will hear the engine pick up if the cleaner is sucked in. Link to comment Share on other sites More sharing options...
