dsracing Posted September 1, 2010 Report Share Posted September 1, 2010 Hi all Will a front wheel out of a k3-k4 Gsxr1000 fit a K5-K6 1000 without mods? Ta. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted September 3, 2010 Report Share Posted September 3, 2010 Suzuki stuff generally swaps but the best thing to do is to check the brake discs have the same fitting and offset - do that by looking at some aftermarket discs and see if they fit both bikes. The wheel hub thickness might be tricky but if you find the other wheel on e-bay you can ask them to measure it for you. Then you need the spindle diameter - see if the bearings or spindle are the same part number Link to comment Share on other sites More sharing options...
gsxr renegade Posted September 3, 2010 Report Share Posted September 3, 2010 The bearings for both wheels have the same part numbers. info taken from here; Alpha Sports Suzuki Link to comment Share on other sites More sharing options...
