kaighn80 Posted August 2, 2010 Report Share Posted August 2, 2010 heard loud pop, fuse blew and now i have a dead short on the main switch live, whats the worst i could have done? Link to comment Share on other sites More sharing options...
jaycee Posted August 2, 2010 Report Share Posted August 2, 2010 heard loud pop, fuse blew and now i have a dead short on the main switch live, whats the worst i could have done? ECU, but hopefully the fuse would have taken the brunt. Perhaps the kill-switch or the ignition relay have been damaged. Link to comment Share on other sites More sharing options...
Conica Posted August 2, 2010 Report Share Posted August 2, 2010 Where were you welding, and where had you earthed? Link to comment Share on other sites More sharing options...
kaighn80 Posted August 2, 2010 Author Report Share Posted August 2, 2010 on the seat subframe for both, the earth clamp was only a few inches from the weld Link to comment Share on other sites More sharing options...
VeeTeeArr Posted August 3, 2010 Report Share Posted August 3, 2010 What sort of welder were you using? Is there a chance a bit of weld spatter could have hit your main cable and melted through earthing it to the frame? Link to comment Share on other sites More sharing options...
kaighn80 Posted August 4, 2010 Author Report Share Posted August 4, 2010 What sort of welder were you using? Is there a chance a bit of weld spatter could have hit your main cable and melted through earthing it to the frame? no ive checked about 90% of the wiring and nothing yet, i was mig welding, does it make a difference? Link to comment Share on other sites More sharing options...
VeeTeeArr Posted August 4, 2010 Report Share Posted August 4, 2010 no ive checked about 90% of the wiring and nothing yet, i was mig welding, does it make a difference? only if bit's of spatter are flying about Link to comment Share on other sites More sharing options...
kaighn80 Posted August 4, 2010 Author Report Share Posted August 4, 2010 turns out i was blonde twice found the problem and it was me so ive fixed it now! yay Link to comment Share on other sites More sharing options...
Conica Posted August 5, 2010 Report Share Posted August 5, 2010 Huzzah! Edit: I can imagine the next thread of this sort "I was using oxy acetylene to trim down my wiring loom and now the bike wont start, anyone got any ideas?!" Link to comment Share on other sites More sharing options...
