Ray Von Posted May 28, 2010 Report Share Posted May 28, 2010 This R80, i've got, the clutch looks like it's stuck to the flywheel, i understand it's a bit like a car clutch being only single disc an all. I've had a butchers and it looks like the gearbox bolts off the engine, what sort of job is it? Also can anyone recommend a decent and reasonable BMW parts supplier? Many thanks Link to comment Share on other sites More sharing options...
ronenige Posted May 29, 2010 Report Share Posted May 29, 2010 These fella's for your bits http://www.motobins.co.uk/ Link to comment Share on other sites More sharing options...
NumberOne Posted May 29, 2010 Report Share Posted May 29, 2010 Not done one myself, but my understanding is that it's a fairly straight forward (if lenghty) job.. with lots to unbolt, it comes off from the rear, the engine stays in the frame. Link to comment Share on other sites More sharing options...
Tomfoolery Posted May 29, 2010 Report Share Posted May 29, 2010 I found Motorworks to be more reliable than Motobins. Link to comment Share on other sites More sharing options...
Egg on Leggs Posted May 29, 2010 Report Share Posted May 29, 2010 I did one about 20 years ago' it was straight forward but I do seem to remember the clutch plate was stuck. This was due to a ring of rust on the shaft splines beyond the clutch plate. Link to comment Share on other sites More sharing options...
