lorenzo Posted May 26, 2010 Report Share Posted May 26, 2010 Moved my bike about the other day and noticed that it'd spooged all its oil all over the side of my bike and the damping is now a bit puny. I suspect that further use will increase the level of spooge excretion until one day it suddenly stops and will spooge no more. The dampers a Nitron one I think (can't remember now, might be a hyperpro actually) but it's a relatively half decent adjustable one, not the stock fixed one that would be a sealed throwaway unit or anything. Anybody got any ideas about how to go about rebuilding it? Link to comment Share on other sites More sharing options...
speedy sie Posted May 28, 2010 Report Share Posted May 28, 2010 iv rebuilt the sprint dampers,by rebuilding it in a buicket of the same oil,a bit messy but you can do it.build them under the oil,so there is no air to get in. Link to comment Share on other sites More sharing options...
lorenzo Posted May 28, 2010 Author Report Share Posted May 28, 2010 What do you do about the seal? Mines oozing out all over the place, so being able to refill it is only half the problem. Link to comment Share on other sites More sharing options...
foo Posted May 28, 2010 Report Share Posted May 28, 2010 I had a Sprint steering damper rebuilt by Sprint, and the cost was quite reasonable -- £50 including supplying a new fitting kit. Maybe Nitron do the same service -- might be worth checking with them? Link to comment Share on other sites More sharing options...
Tomfoolery Posted May 28, 2010 Report Share Posted May 28, 2010 MCT do 'em, too. Quick service, well recommended. Link to comment Share on other sites More sharing options...
thefatman Posted May 28, 2010 Report Share Posted May 28, 2010 Take the seal out, measure it up, order a new one, put it back together again. You'll get a seal from Nitron, or here is the seal calculator http://www.simplybearings.co.uk/shop/oil_seals.php Link to comment Share on other sites More sharing options...
