Romski Posted May 21, 2010 Report Share Posted May 21, 2010 Need to upgrade the master cylinder on my k1 track bike as they are fubar-what else fits without loads of aggro?? cheers. Link to comment Share on other sites More sharing options...
kja.busa Posted May 21, 2010 Report Share Posted May 21, 2010 Need to upgrade the master cylinder on my k1 track bike as they are fubar-what else fits without loads of aggro?? cheers. A radial master cylinder from the later GSX-R's is a good replacement, alternatively, the later R6/R1 stuff is good too, don't pay over the odds though, for a little over £100 you can get one of the Accosato radial master cylinders, a cheaper alternative to Brembo and just as good on my opinion. Link to comment Share on other sites More sharing options...
TQ_uk Posted May 25, 2010 Report Share Posted May 25, 2010 A radial master cylinder from the later GSX-R's is a good replacement, alternatively, the later R6/R1 stuff is good too, don't pay over the odds though, for a little over £100 you can get one of the Accosato radial master cylinders, a cheaper alternative to Brembo and just as good on my opinion. Indeed - put one off (I think) a K5 1000 on mine. Had to file down the tabs that stop the banjo rotating, to enable HEL adaptor kit to fit at the correct angle, but that was 5 mins with a Dremel Also had to drill another hole in the reservoir bracket (m/c didn't come with one so reused the K1 one) to move it closer so hose wasn't kinked. All in all pretty straight forward, and massive improvement (though I did strip & rebuild front calipers at same time so that may have helped ) Link to comment Share on other sites More sharing options...
