gook184 Posted May 20, 2010 Report Share Posted May 20, 2010 My linkage doesn't have grease nipples so I have to whip it apart for greasing every 2 years. Would it be possible to drill, tap and fit some grease nipples? The only downside i can think of is that it would weaken the structures involved. Link to comment Share on other sites More sharing options...
jezz Posted May 20, 2010 Report Share Posted May 20, 2010 Hi Yes fit grease nipples. Properly drilled and tapped you will have no issue and no..... it wont be any weaker. The grease nipple shoudl be in the middle of the bearing 'tube' well away from any high stress areas Link to comment Share on other sites More sharing options...
gook184 Posted May 20, 2010 Author Report Share Posted May 20, 2010 Righto, I'll do it. Thanks Jezz. If anybody else comes on and says don't do it, you're too late, I'll be in t'shed for the rest of the evening. Link to comment Share on other sites More sharing options...
