Chrisball Posted May 19, 2010 Report Share Posted May 19, 2010 Im doing a CCT on my mates GSxr K2 tonight, not worked on many Gsxr's so has anyone got any pointers regarding this job? Fitting an OEM auto tensioner so no need to arse around with a manual one. Can it be got at from behind the right side fairing or is it tank and airbox off job? Any info would be great Chris Link to comment Share on other sites More sharing options...
chance Posted May 19, 2010 Report Share Posted May 19, 2010 remove the tank and airbox as you need to get at it from above. you may find you need to remove the throttle bodies as well but tbh everything is easy to do, i find my gsxr pleasantly easy to work on Link to comment Share on other sites More sharing options...
Chrisball Posted May 19, 2010 Author Report Share Posted May 19, 2010 Cheers lads, thought the tank and airbox would have to come off. Link to comment Share on other sites More sharing options...
Chrisball Posted May 19, 2010 Author Report Share Posted May 19, 2010 Cheers mate, but new cam chain tensioner fitted and the bike sounded alot better. But now the guy has rang me when he had got home and has said the bike wont rev out very well over 7000 rpm! Ive told him to check the secondard throttle valve servo as i had that off. but he says thats all good. So the only other thing that it could be is while lifting the tank on and off and tipped up it has filled the fuel filter full of shite. Even when we started the bike and the fuel pump primed it sounded to struggle to me and he cant remember ever having the filter changed. So im hoping its the filter! Anybody else any ideas?? Cheers Link to comment Share on other sites More sharing options...
chance Posted May 19, 2010 Report Share Posted May 19, 2010 more likely youve left something unplugged under the tank.just hinge the tank up and have a check, might be the one on the airbox or related to the throttle bodies Link to comment Share on other sites More sharing options...
chance Posted May 19, 2010 Report Share Posted May 19, 2010 oh and make sure your not kinking the fuel line under the tank Link to comment Share on other sites More sharing options...
