gsxr renegade Posted May 17, 2010 Report Share Posted May 17, 2010 Right, daft as it sounds, does anyone know the best way of cleaning oil off a tyre without damaging it? Was riding to work today, after messing about with the clutch at the weekend, and i don't think the gasket has sealed properly when i put the clutch cover back on, meaning i have a small oil leak, but in the time it took me to get to work this morning, there is oil all over the side of the bike, and in a nice strip all the way around the right hand side of my tyre. Does anyone know how to clean the oil off without damaging the tyre? I'm gonna need to wash the oil off the side of the bike tonight, so will warm soapy water do the trick? I know i should really get a new tyre, but i can't afford one, at least until payday anyway. Link to comment Share on other sites More sharing options...
Tomfoolery Posted May 17, 2010 Report Share Posted May 17, 2010 New tyre? Fuck off! Petrol should be alright if it's not left on the tyre for too long. It's what I've used in the past. Link to comment Share on other sites More sharing options...
gsxr renegade Posted May 17, 2010 Author Report Share Posted May 17, 2010 New tyre? Fuck off! Petrol should be alright if it's not left on the tyre for too long. It's what I've used in the past. Nice one, was thinking of using a bit of petrol, but wasn't sure if it would do bad things to the tyre. Link to comment Share on other sites More sharing options...
jollygiant Posted May 17, 2010 Report Share Posted May 17, 2010 As long as you use a match aswell?!?!?!? Thats what I've used in the past.. Just soak a rag and keep wiping it!! Oh and plenty of changing of rags as you don't really want to be wiping it back on?? Link to comment Share on other sites More sharing options...
budda Posted May 17, 2010 Report Share Posted May 17, 2010 The sump plug fell out of my 7r a few years ago, massive drift on and coasted to a stop, pure fluke I didn't crash. The tyre was completely covered in oil I just washed it off with washing up liquid and hot water, scrubbed it real good with a brush and it was right as rain. Get em washed they'll be reet. Link to comment Share on other sites More sharing options...
jaycee Posted May 17, 2010 Report Share Posted May 17, 2010 I used brake cleaner when I accidentally spilled brake fluid on mine, then rinsed it off with the hose sharpish. Link to comment Share on other sites More sharing options...
BenW Posted May 17, 2010 Report Share Posted May 17, 2010 Right, daft as it sounds, does anyone know the best way of cleaning oil off a tyre without damaging it? Was riding to work today, after messing about with the clutch at the weekend, and i don't think the gasket has sealed properly when i put the clutch cover back on, meaning i have a small oil leak, but in the time it took me to get to work this morning, there is oil all over the side of the bike, and in a nice strip all the way around the right hand side of my tyre. Does anyone know how to clean the oil off without damaging the tyre? I'm gonna need to wash the oil off the side of the bike tonight, so will warm soapy water do the trick? I know i should really get a new tyre, but i can't afford one, at least until payday anyway. I use a bit of brake cleaner sprayed onto a cloth - many racers use it to clear the release compound off the tyre. It evaporates quickly and is designed not to damage the rubber seals in brake calipers anyway. Mark White at M&M swears by the stuff. B Link to comment Share on other sites More sharing options...
jaycee Posted May 17, 2010 Report Share Posted May 17, 2010 See i knew (ok, hoped) Iwasn't being stupid by using brake cleaner Link to comment Share on other sites More sharing options...
Kayla Posted May 17, 2010 Report Share Posted May 17, 2010 I'd have thought something like Muc Off would work well on oil and it's water soluble so won't shouldn't knacker the tyre. Link to comment Share on other sites More sharing options...
gook184 Posted May 17, 2010 Report Share Posted May 17, 2010 I've used petrol, it worked fine, i've also used muc off and it needed more effort but made me feel better than using petrol. Those fossils didn't die to be used for cleaning. Link to comment Share on other sites More sharing options...
Bat Fastard Posted May 17, 2010 Report Share Posted May 17, 2010 As said, Brake cleaner. Link to comment Share on other sites More sharing options...
Timbo S2 Posted May 17, 2010 Report Share Posted May 17, 2010 Do a burnout on that bit. Is the correct answer. Ten points. (Failing that, brake cleaner. Then a burnout). Link to comment Share on other sites More sharing options...
krazyk Posted May 17, 2010 Report Share Posted May 17, 2010 brake cleaner first then- Washing up liquid ( Works in porn films) rinse off,lastly dry with clean rags. Link to comment Share on other sites More sharing options...
gsxr renegade Posted May 18, 2010 Author Report Share Posted May 18, 2010 Cheers for the advice chaps and chapettes. Cleaned it off last night using a mix of everything! bit of hot soapy water, bit of a blast with the pressure washer, then a bit of a scrub with some petrol and it seemed to work fine. Took it nice and steady on the way in to work this morning, and now it just looks like i've got a massive chicken strip down one side of my tyre! Link to comment Share on other sites More sharing options...
