Wildcard Posted May 17, 2010 Report Share Posted May 17, 2010 Will the link pipe and can (aftermarket) from an 02-03 R1 fit a 98 R1?? Link to comment Share on other sites More sharing options...
MonkeyJim Posted May 17, 2010 Report Share Posted May 17, 2010 Will the link pipe and can (aftermarket) from an 02-03 R1 fit a 98 R1?? IIRC the answer is no. Or rather, not without work. The can would probably be interchangeable. But whilst the engine is the same basically [carbs vs FI aside], the link pipe is different. It has to account for a different swingarm and subframe. HTH Link to comment Share on other sites More sharing options...
Wildcard Posted May 26, 2010 Author Report Share Posted May 26, 2010 IIRC the answer is no. Or rather, not without work. The can would probably be interchangeable. But whilst the engine is the same basically [carbs vs FI aside], the link pipe is different. It has to account for a different swingarm and subframe. HTH Thank you Link to comment Share on other sites More sharing options...
