matbmx100 Posted May 13, 2010 Report Share Posted May 13, 2010 Hi Guys Just a quick one, on my new to me srad ive noticed that the pads are rattling slightly in the calipers. I can hear it when riding at low speed and can move them slightly in the caliper when stopped they seem to be braking as normal but just have a little bit of play in them is this normal? Just to reiterate the brakes seem to working well still I dont know what pads they are but im assuming they are aftermarket and therefore slightly the wrong shape? Thanks matt Link to comment Share on other sites More sharing options...
gurninman Posted May 13, 2010 Report Share Posted May 13, 2010 Is it just a single slider pin holding them ? if so, they do tend to rattle a bit Link to comment Share on other sites More sharing options...
MonkeyJim Posted May 13, 2010 Report Share Posted May 13, 2010 Are the anti-rattle shims present and correct? Link to comment Share on other sites More sharing options...
fran9r Posted May 13, 2010 Report Share Posted May 13, 2010 Has it done a lot of miles? Wear is common on the (same) calipers on the 6 and 9R. Link to comment Share on other sites More sharing options...
speedy sie Posted May 13, 2010 Report Share Posted May 13, 2010 had this my self,could be the pad backing,or worn disk bobbins pushing the pads apart,causing them to rattle.or the calipers have wear each side of the pads edge,winter corrosion. no worries,as long as it brakes ok. Link to comment Share on other sites More sharing options...
Gregorious77 Posted May 13, 2010 Report Share Posted May 13, 2010 My 6R does the same and it is annoying as fuck in low speed traffic, everytime you brake "click" (not head bearings as I just replaced those) Link to comment Share on other sites More sharing options...
matbmx100 Posted May 13, 2010 Author Report Share Posted May 13, 2010 Cheers guys I think its all good just a bit odd i think si's prob right and it might just be the calipers worn slightly, in answer fran its done about 30k so has a few under its belt. Glad its not just mine thats doing it, mate has a brand new set of pads so i might stick them in with new pins just to be sure thanks guys Matt Link to comment Share on other sites More sharing options...
Harry Muff Posted May 15, 2010 Report Share Posted May 15, 2010 My 6R does the same and it is annoying as fuck in low speed traffic, everytime you brake "click" (not head bearings as I just replaced those) If you've just changed the head bearings then they are more likely than ever to click as they are slowly bedding in and need a tighten or two. Link to comment Share on other sites More sharing options...
Gregorious77 Posted May 15, 2010 Report Share Posted May 15, 2010 Its deffo the pads I have checked with the front wheel off the ground in the garage. Link to comment Share on other sites More sharing options...
gook184 Posted May 15, 2010 Report Share Posted May 15, 2010 My 6R has 4 pot tokicos with a bit of wear on the calipers. Same audible annoying clicking as you have. I glue a sliver of lorry curtain to the leading edge of the pads and now there's no more clicking. Link to comment Share on other sites More sharing options...
