Mark/Foggy Posted April 28, 2010 Report Share Posted April 28, 2010 Need to know my options for a right way up fork, maximum diameter 38mm in stanchions. Preload, compression and rebound ideally. Little project coming up. Handbuilt tube, steel frame, 1000cc engine etc. May be taking on some serious players with it. What do we know then. Link to comment Share on other sites More sharing options...
Kayla Posted April 28, 2010 Report Share Posted April 28, 2010 Need to know my options for a right way up fork, maximum diameter 38mm in stanchions. Preload, compression and rebound ideally. Little project coming up. Handbuilt tube, steel frame, 1000cc engine etc. May be taking on some serious players with it. What do we know then. http://www.customfighters.com/forums/showthread.php?t=17555 Take your pick edit- what about rwu MX forks? They should be reasonably adjustable Link to comment Share on other sites More sharing options...
Mark/Foggy Posted April 28, 2010 Author Report Share Posted April 28, 2010 http://www.customfighters.com/forums/showthread.php?t=17555 Take your pick edit- what about rwu MX forks? They should be reasonably adjustable You young lady are an absolute treasure Was thinking FZR600 myself, any adjustment on these? Link to comment Share on other sites More sharing options...
dodgy_tom Posted April 28, 2010 Report Share Posted April 28, 2010 You young lady are an absolute treasure Was thinking FZR600 myself, any adjustment on these? I have a set in my shed, and the answer to your question is no. edit- although what about the import 400 forks? Link to comment Share on other sites More sharing options...
Kayla Posted April 28, 2010 Report Share Posted April 28, 2010 edit- although what about the import 400 forks? The early ones are 38mm but unadjustable and the later ones are too fat (41mm and 43mm for the 3EN2 and 3TJ respectively). Link to comment Share on other sites More sharing options...
Mark/Foggy Posted April 28, 2010 Author Report Share Posted April 28, 2010 The early ones are 38mm but unadjustable and the later ones are too fat (41mm and 43mm for the 3EN2 and 3TJ respectively). But, you ya little minx have struck exactly the right chord for my highly devious mind. Set of crossers it is. I can angle grinder off the existing brake mounts and with our friend TIG the Magic Glue Gun, we'll have 'proper set of unidentifiable forks'. Heh, Heh, Heh. I even have a mate that works for Fox suspension. He'll be able to rig the length and disguise the fork caps. Nice set of Mr O's internals, nobody will ever know. He's recently converted a standard set of rebound only shocks to run Gas, should be right up his street this little project. Link to comment Share on other sites More sharing options...
