Dom Posted April 12, 2010 Report Share Posted April 12, 2010 OK chaps, I've just fitted a Brembo RCS and HEL lines to my '05 ZX10 (what a difference!!!) and have a question about the switch. Do I need to cut the existing connector off the end of the old brake light cable and then attach the wires from the Brembo switch? What sort of adapters should I use? Should I cut it at the M/C end or lower down the wiring loom? I have some of the 'bullet' type electrical connectors kicking around, would they be okay? Or is the area a little exposed for that type of connection? Lots of questions! Link to comment Share on other sites More sharing options...
yamfan Posted April 12, 2010 Report Share Posted April 12, 2010 I,ve got the same set up on mine and what i did was left the original wiring block in place cut the brembo switch down crimped on some male plugs which had to be ground down to size i could,nt find any small enough anywhere,this worked ok for a while then it came off so now i,ve soldered them on. I didnt fancy cutting the original wiring & thought it would be easier to put back to standard if i sell it. HTH Link to comment Share on other sites More sharing options...
Dom Posted April 13, 2010 Author Report Share Posted April 13, 2010 I,ve got the same set up on mine and what i did was left the original wiring block in place cut the brembo switch down crimped on some male plugs which had to be ground down to size i could,nt find any small enough anywhere,this worked ok for a while then it came off so now i,ve soldered them on. I didnt fancy cutting the original wiring & thought it would be easier to put back to standard if i sell it. HTH I like this idea! I have some spade connectors and with some sort of trimming/grinding I reckon they'll fit into the existing connector. I may have to buy a dremel to achieve this though - shame! Link to comment Share on other sites More sharing options...
