Adam Posted April 9, 2010 Report Share Posted April 9, 2010 just wondering if anyone out there has ever made there own cylinder liners. What grade of cast iron did you use, and where did you get it from. I'm after raw material rather than liner blanks. Thanks in advance. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted April 12, 2010 Report Share Posted April 12, 2010 I don't think it's cast iron !!! Your looking at some form of carbon steel which is rolled to basic shape. There's probably a pleening process too, that will close up any voids. You should be able to buy cylinder liners ... try somebody like TTS, Holeshot, or Big CC Link to comment Share on other sites More sharing options...
Adam Posted April 17, 2010 Author Report Share Posted April 17, 2010 i thought they were usually made from spheroidal grew cast iron?I don't think it's cast iron !!! Your looking at some form of carbon steel which is rolled to basic shape. There's probably a pleening process too, that will close up any voids. You should be able to buy cylinder liners ... try somebody like TTS, Holeshot, or Big CC Link to comment Share on other sites More sharing options...
porter_jamie Posted April 17, 2010 Report Share Posted April 17, 2010 make it from ally and plate it. Much better. Ask your piston/ring supplier what clearance to run and you should find that ally liners allow u to run much tighter which is better 4 blowby etc Link to comment Share on other sites More sharing options...
marcaztls Posted April 17, 2010 Report Share Posted April 17, 2010 If you want the some of the best, use these guys: http://www.capricorngroup.net/no_cache/en.html Link to comment Share on other sites More sharing options...
Adam Posted April 17, 2010 Author Report Share Posted April 17, 2010 yeah plated barrels would be the way but if my barrel and port design isn't right then it'll become an expensive deal to keep getting them plated. My kart engines always had cast iron liners and didn't suffer from any blowby problems. make it from ally and plate it. Much better. Ask your piston/ring supplier what clearance to run and you should find that ally liners allow u to run much tighter which is better 4 blowby etc Link to comment Share on other sites More sharing options...
Tim Radley Posted April 20, 2010 Report Share Posted April 20, 2010 Speak to either capricorn or westwood liners. Don't try and make your own its much easier to buy the blanks Link to comment Share on other sites More sharing options...
Adam Posted April 20, 2010 Author Report Share Posted April 20, 2010 If i can get hold of some suitable material in the right condition it'd be loads easier. I'd've thought someone out there would know!Speak to either capricorn or westwood liners. Don't try and make your own its much easier to buy the blanks Link to comment Share on other sites More sharing options...
Gregorious77 Posted April 29, 2010 Report Share Posted April 29, 2010 I have to answer an assignment question on cylinder blocks, liners and crankshaft material spec and manufacture. Here is one link I have found that may help site Material Standard IS 210, GG25, ASTM A48 but can be deviated according to customer requirements. Hardness : 210 – 275 BHN Tensile: 25kgf/sq. mm Graphite: Type A & B (D&E Random) Flake size: 4-6 Free Ferrite: Less than 3% Matrix: Fine Lamellar & Sorbitic Pearlite Surface Roughness: Ra 0.4 to 0.8 micron Rz 4 to 7 micron Vo 0.16 to 0.45 Link to comment Share on other sites More sharing options...
Gregorious77 Posted April 29, 2010 Report Share Posted April 29, 2010 More information. it is evident that the liners are produced by a centrifugal casting operation, and then heat treated. Machining operations are then performed on the liners, i.e., rough turning of outer diameter (OD), turning of external features to manufacturer specifications, and rough boring of liner inner diameter (ID). Following the completion of the rough boring operation, each liner is inspected, then an oil film is applied to prevent rusting, and finally the liners are packaged and shipped to the engine manufacturer. It may be noted that once the liners are received at engine manufacturer, the liners are inserted as cores in the block casting operation. The engine manufacturer subsequently performs a finish ID boring operation, and a honing operation on the cylinder (liner) wall surface. Looks like you should buy the liners you need due to the complexity of manufacture, unless you have heat treating facilitys etc. Link to comment Share on other sites More sharing options...
Dr Dufus Posted April 29, 2010 Report Share Posted April 29, 2010 More information. it is evident that the liners are produced by a centrifugal casting operation, and then heat treated. Machining operations are then performed on the liners, i.e., rough turning of outer diameter (OD), turning of external features to manufacturer specifications, and rough boring of liner inner diameter (ID). Following the completion of the rough boring operation, each liner is inspected, then an oil film is applied to prevent rusting, and finally the liners are packaged and shipped to the engine manufacturer. It may be noted that once the liners are received at engine manufacturer, the liners are inserted as cores in the block casting operation. The engine manufacturer subsequently performs a finish ID boring operation, and a honing operation on the cylinder (liner) wall surface. Looks like you should buy the liners you need due to the complexity of manufacture, unless you have heat treating facilitys etc. try LA sleeve company in states they make liners for most make of engine bike car or boat!!! wiseco pistons also make sleave, i use liners in f1 boat engines and have to say best to buy from a company that has all ready done the devolpment and testing befor you buy!!! Link to comment Share on other sites More sharing options...
addiction269 Posted April 29, 2010 Report Share Posted April 29, 2010 all i know is that they use nikasil liners for the lambrettas - apparently its good stuff - not a scooter boy so i dont know much about the stuff! Link to comment Share on other sites More sharing options...
Gregorious77 Posted April 29, 2010 Report Share Posted April 29, 2010 Nikasil is an electroplated coating in an aluminium bore, no need for liners. Link to comment Share on other sites More sharing options...
lorenzo Posted April 29, 2010 Report Share Posted April 29, 2010 Yup, and nikasil is used on ferkin loads of things, has been since the early 90's. Lambrettas originally had a cast iron liner I think, certainly vespas did originally. Link to comment Share on other sites More sharing options...
