Tom Mac Posted April 9, 2010 Report Share Posted April 9, 2010 or a bit more simply: does anyone know if a Brembo rear brake master cylinder off an R1 will fit an early EXUP (FZR thou)? Bolt hole diameter and postion looks identical inthe pics but don't want to flash the cash and then find out it don't fit. ta in advance and all that Tom Link to comment Share on other sites More sharing options...
MonkeyJim Posted April 9, 2010 Report Share Posted April 9, 2010 or a bit more simply: does anyone know if a Brembo rear brake master cylinder off an R1 will fit an early EXUP (FZR thou)? Bolt hole diameter and postion looks identical inthe pics but don't want to flash the cash and then find out it don't fit. ta in advance and all that Tom Tom I have a feeling that I have a spare early R1 rear brake m/c lurking in the Batcave somewhere... seem to recall it came attached to some harris rearsets I bought a while ago I'll have a look when down at t'garage over t'weekend. If I've got it, I can bung it in the post to you to try it out. jim Link to comment Share on other sites More sharing options...
Tom Mac Posted April 9, 2010 Author Report Share Posted April 9, 2010 Tom I have a feeling that I have a spare early R1 rear brake m/c lurking in the Batcave somewhere... seem to recall it came attached to some harris rearsets I bought a while ago I'll have a look when down at t'garage over t'weekend. If I've got it, I can bung it in the post to you to try it out. jim That would be most fantastic. cheers Link to comment Share on other sites More sharing options...
MonkeyJim Posted April 12, 2010 Report Share Posted April 12, 2010 That would be most fantastic. cheers Brembo R1 rear m/c found let me have your address Sir and I will bung it in the post to you. Link to comment Share on other sites More sharing options...
Tom Mac Posted April 12, 2010 Author Report Share Posted April 12, 2010 Brembo R1 rear m/c found let me have your address Sir and I will bung it in the post to you. a PM should be winging its way across cyberspace to you now ta very much Link to comment Share on other sites More sharing options...
