Gixxerthou Posted April 2, 2010 Report Share Posted April 2, 2010 I've noticed my threads on the TL sump are looking a bit worn through many years of regular oil changes. I do have a helicoil kit but wondered if this was a wise thing to do. The alternative is engine out and new engine case on, which I know through experience is a world of pain. looking forward to your replies. Cheers Link to comment Share on other sites More sharing options...
Grumpyduck Posted April 2, 2010 Report Share Posted April 2, 2010 Personally I would helicoil it. I had a GSXR 750 a few years back and did one of the threads in the head for holding down a rocker (instead of fitting a new head) and its still going now. Engine out and fitting new cases is a little extreme, provided you do the job properly with care you should have no trouble for years to come. IMHO. GD Link to comment Share on other sites More sharing options...
bignige Posted April 2, 2010 Report Share Posted April 2, 2010 my sump plug was heli coiled probably 40,000 miles ago 20 oil changes later its still going strong! my only thought ,is there different brand heli-coils ? in other words- the best u can afford? Link to comment Share on other sites More sharing options...
speedy sie Posted April 2, 2010 Report Share Posted April 2, 2010 heli coils are shit,but i carnt remember wot you call these thing i think,its a squish thred,that is riveted in place,i use to do all my sprint two stokes with these as the thred is stronger than ali,and it never blew one out ,not even with 21 to 1 compresion,on methonol.1050 mail jets eny one,amil 40mm an a 240cc single. Link to comment Share on other sites More sharing options...
speedy sie Posted April 2, 2010 Report Share Posted April 2, 2010 Helicoiling it will be fine...using a Timsert would be better. thats the thing i was trying to remember,bloody good things,id rather use these than a heli coil eny day. Link to comment Share on other sites More sharing options...
zx6rrob Posted April 2, 2010 Report Share Posted April 2, 2010 Rog, if you don`t fancy doing it yourself we use a real good engineering type chap at work who sorts all our shit out. Drop us a pm if you want his number. Link to comment Share on other sites More sharing options...
ronenige Posted April 3, 2010 Report Share Posted April 3, 2010 if your going to use a timesert be careful what length's you use , must Suzuki sump's are quite shallow ( like their owner's ? ) with a portion of the thread removed to allow good drainage , if you use a helicoil this cut out can make it a bit fiddly to get it in , take your time and feel what's going on and you'll be ok Link to comment Share on other sites More sharing options...
Gixxerthou Posted April 4, 2010 Author Report Share Posted April 4, 2010 if your going to use a timesert be careful what length's you use , must Suzuki sump's are quite shallow ( like their owner's ? ) with a portion of the thread removed to allow good drainage , if you use a helicoil this cut out can make it a bit fiddly to get it in , take your time and feel what's going on and you'll be ok erm cheers... I think Link to comment Share on other sites More sharing options...
control_67 Posted April 5, 2010 Report Share Posted April 5, 2010 I have timeserts in the eccentric adjusters on my JMC swingarm after the stock helicoils stripped on both sides. Fantastic things, much more solid than helis. Link to comment Share on other sites More sharing options...
