willbloke Posted July 2, 2010 Report Share Posted July 2, 2010 I've only just seen this thread .... Anyhoo , if anyone else is having trouble with seized in shafts etc. I picked up some freezer disassembly stuff years ago , never needed it of course , but the idea is it freezes the part thereby allowing the lube to soak in and I think the shock of the freeze helps loosen it. Can't be arsed to go to garage and try and find it , but I think it was made by Wurth ? Link to comment Share on other sites More sharing options...
zx6rrob Posted July 2, 2010 Report Share Posted July 2, 2010 I've only just seen this thread .... Anyhoo , if anyone else is having trouble with seized in shafts etc. I picked up some freezer disassembly stuff years ago , never needed it of course , but the idea is it freezes the part thereby allowing the lube to soak in and I think the shock of the freeze helps loosen it. Can't be arsed to go to garage and try and find it , but I think it was made by Wurth ? I`ll be honest...... its wank!! Never used one that actually worked. Sorry dude, just had to say it. Rob Link to comment Share on other sites More sharing options...
deviant Posted July 2, 2010 Report Share Posted July 2, 2010 I have...taking a pressed (and we think glued) gear off a shaft a few years back - it took a blowtorch on the outside, freezer spray up the inside of the shaft, and a ten ton press to shift the fucker, and it made a hell of a bang when it moved. Link to comment Share on other sites More sharing options...
Guest Posted July 3, 2010 Report Share Posted July 3, 2010 if anyone else is having trouble with seized in shafts Fnarr. the idea is it freezes the part thereby allowing the lube to soak in and I think the shock of the freeze helps loosen it. Fnarr. I`ll be honest...... its wank!! In context, fnarr. it took a blowtorch on the outside, freezer spray up the inside of the shaft, and a ten ton press to shift the fucker, and it made a hell of a bang when it moved. I'll say it again: fnarr!!! Link to comment Share on other sites More sharing options...
willbloke Posted July 4, 2010 Report Share Posted July 4, 2010 I`ll be honest...... its wank!! Never used one that actually worked. Sorry dude, just had to say it. Rob Fairy snuff ! As I said , I've never used it , but it seemed like a good idea. Maybe that's why , when I tried Googleing it , I couldn't find it . Link to comment Share on other sites More sharing options...
