scwirral Posted March 16, 2010 Report Share Posted March 16, 2010 Domed Allen Key Head M6 thread (1.00 pitch) x17mm length I've ordered some of the new old stock EBC discs (thanks for the find, Heds), and a VFR800 17 inch wheel to do the conversion (thanks RussBlade) I'm hoping to pick up a cheap rear wheel so that I can have two serviceable sets of wheels I can use. Anyhoo, I want to know where I can get disc bolts for sensible money. The Dave Silver parts are genuine Honda (ie made of chewing gum). Any better suggestions? Link to comment Share on other sites More sharing options...
Matt69 Posted March 17, 2010 Report Share Posted March 17, 2010 Will these do? http://www.stagonset.co.uk/fasteners?cart_...ews|With|Flange Scroll down they have a 16mm long one. Matt Link to comment Share on other sites More sharing options...
heds954 Posted March 17, 2010 Report Share Posted March 17, 2010 I've ordered some of the new old stock EBC discs (thanks for the find, Heds) No probs I went through the same thoughts myself, £20 for a dozen bolts doesn't half make you wince, but then it is for a safety critical part of your bike? But then, I found that the previous owner of the wheels I'd bought had kindly left the old bolts in, so with a good inspection and having chipped off carefully the old thread lock and reapplied new thread lock, I used them again Link to comment Share on other sites More sharing options...
scwirral Posted March 18, 2010 Author Report Share Posted March 18, 2010 .....I found that the previous owner of the wheels I'd bought had kindly left the old bolts in, so with a good inspection and having chipped off carefully the old thread lock and reapplied new thread lock, I used them again Makes up for all the piss takes about your disc being the last to land, chief! BTW, don't know if it is a bad thing to do, but I've previously taken old thread lock off with a quick waft of a hot air gun. Not serious heat that could affect the temper, just enough to encourage a bit of distorting of the plastic(?) adhesive itself. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted March 19, 2010 Report Share Posted March 19, 2010 Will these do? http://www.stagonset.co.uk/fasteners?cart_...ews|With|Flange Scroll down they have a 16mm long one. Matt You need A4 grade for disk bolts Link to comment Share on other sites More sharing options...
will#224 Posted March 19, 2010 Report Share Posted March 19, 2010 You need A4 grade for disk bolts A4 80 isn't it? Link to comment Share on other sites More sharing options...
