Gobert23 Posted February 15, 2010 Report Share Posted February 15, 2010 This may be one of those jobs which involves 'getting/giving it to someone who can', but I can't see why I can't clean up a set of discs, actually the disc carriers/centres myself... I've got a set of early Brembo discs (for my Strada), where the 'paint' finish on the carriers has started to (badly) flake and peel away. Other than using a (nasty) rattle can, does anyone have any ideas on how to clean these back and re-furbish them to look like new?? G Link to comment Share on other sites More sharing options...
speedy sie Posted February 15, 2010 Report Share Posted February 15, 2010 soft pad grinder,then hammaright,looking good as new. Link to comment Share on other sites More sharing options...
Gobert23 Posted February 15, 2010 Author Report Share Posted February 15, 2010 Should I just mask up the bobbins/carriers (since I can't split the outer disc/rotor from the carrier)?? Link to comment Share on other sites More sharing options...
tootall Posted February 15, 2010 Report Share Posted February 15, 2010 Why can't you split the carrier/disc? Honestly don't reckon you'll get a decent result without seperating them. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted February 15, 2010 Report Share Posted February 15, 2010 i've painted a few on my disk carriers and the masking up is the longest part of it. Clean them in the kitchen sink or dish washer first. Mask up the mating surface and put it on the wheel, then draw round the wheel so when you cut the tape and spray the paint isn't on the matting surface. I used 5 wheels silver because it was a close enough match to standard colour then put them in the oven to warm through (not hot just warm). Then I sprayed them, let them dry, then in and out the oven to cure the paint. Works fine. You can use brake caliper paint if you want a different colour Link to comment Share on other sites More sharing options...
krazyk Posted February 15, 2010 Report Share Posted February 15, 2010 i've painted a few on my disk carriers and the masking up is the longest part of it. Clean them in the kitchen sink or dish washer first. Mask up the mating surface and put it on the wheel, then draw round the wheel so when you cut the tape and spray the paint isn't on the matting surface. I used 5 wheels silver because it was a close enough match to standard colour then put them in the oven to warm through (not hot just warm). Then I sprayed them, let them dry, then in and out the oven to cure the paint. Works fine. You can use brake caliper paint if you want a different colour They´re now called BAKE discs Link to comment Share on other sites More sharing options...
Gobert23 Posted February 15, 2010 Author Report Share Posted February 15, 2010 Why can't you split the carrier/disc? Honestly don't reckon you'll get a decent result without seperating them. I wouldn't honestly know where to start, in splitting a set of discs from their carriers... Also, I've never been able to find anyone that'll supply just the bobbins (from previous experiences). As I said, I can see this turning into a job that'll need handed over to someone else, if I want to make a decent job of it (and that I do...) Leave em, it's not the end of the world. True, but these discs aren't about the 'working' aspect and much more about having the correct part(s), in good clean condition, on the 916 Strada. I been very carefully restoring all the original parts (making sure that the parts are the correct year, stamp, etc). G Link to comment Share on other sites More sharing options...
Evilchicken0 Posted February 16, 2010 Report Share Posted February 16, 2010 True, but these discs aren't about the 'working' aspect and much more about having the correct part(s), in good clean condition, on the 916 Strada. I been very carefully restoring all the original parts (making sure that the parts are the correct year, stamp, etc). G ahhhh - um if your restoring to any kind of original then you'll probably want the carriers re-anodised. I had the washers on my Bimota disks (similar to yours) replaced by Stealth Engineering ... cost about £50 including postage there and back. they make disks so they can probably get them re-anodised - ask them for a quote. Or try the the anodisers in Brighton they have a post in the Trade Pinboard section. Link to comment Share on other sites More sharing options...
